Question about Samsung PCL542R 54" Rear Projection Television
Worked great until.........................
Until one time I tried to turn it on and could hear a little scratch/hiss noise coming out of the rear. So I shut it off and unplugged it. Later tried it again and when I plug it in the little green light comes on and then shuts off but nothing happens. I deal with all kinds of electronics almost daily but have never messed with a TV. One of my buddies has a RCA D56W20 and it had a pretty similar problem; he had it repaired and they replaced the flyback and horizontal. Would that be what is wrong with mine? If so where can I get parts or necessary componets to fix?
  • Samsung Master
  • 8,617 Answers
It could quite possibly be the flyback and horizontal. However I would suggest getting the service manual for your set. It will give you the info so you dont replace things you dont need. The following link has your service manual for your set.They also offer free unlimited support along with the manual. Also if you'd rather have it emailed to you they will do that also. You just have to go back to the site after you order and provide an email address requesting they email the manual and support instructions to you instead of mailing them. Thats the best way to go instead of blindly buying parts that you may not need. Hers the link
http://servicemanuals.vstore.ca/
Posted on Jan 17, 2008
Mic not working on toshiba a665 laptop; hisses
Get rid of all possible noise in your recording space. Pick the least noisy area to record in. Turn off any fans, heaters, air conditioners and other nonessential devices. Even an extra laptop or idle gaming console makes noise, so if you're not using it, shut it off. Close the doors and shut the windows. Place your microphone away from any remaining noise sources, including power sources. Don't record next to a window, even if it's closed. Remember that your computer makes noise, too. Even sounds your ear can't hear will become noticeable once you amplify your recording. Finally, turn off any cellphones. GSM buzz can be picked up in your recording, so do not set the phone to vibrate. Turn it completely off. Get as close to the mic as possible. Positioning for tonality and comfort has to be taken into consideration, but beyond that you simply want to get as close as you can. The closer the microphone is to the audio source, the less background noise will show up in the recording. Turning up your source will accomplish a similar effect. Simply speak louder, or if you're recording an electric instrument, turn up the volume. If your levels start clipping, bring the volume down on the mixer. Tweak the EQ. After your audio is recorded, you can often eliminate noticeable buzz or hiss using the equalizer. If your mixer has equalizer presets, try playing with those before you start recording to see what bands you can turn down to diminish noise. If you're mixing digitally, you can record the audio straight in without any EQ and apply one during the editing process. Finding the right equalizer band to mix down is often a process of trial and error. If it's a hissing sound, it's going to be in the higher spectrum. If it's a buzzing sound, it's probably coming from the mid to lower spectrum. A graphic equalizer is a great mechanism to form a valley in the EQ and move it around until the noise is reduced. Use a speech enhancer plugin. Any good mixing program has one; even something as simple as Apple's GarageBand can do the trick. Or, try searching the Internet for a third-party plugin. The speech enhancer will let you apply some quick tone settings to make a speaking voice sound more professional. More importantly, it will give you the option to dial back the more quiet sounds in a recording. This will help isolate the vocal and push everything out. While this type of plug-in is meant for spoken audio, it can be used -- with mixed results -- on any kind of audio. Know your noise gate. The noise gate is your key to absolutely silent pauses and crystal clean audio. The gate takes out all noises under a certain level and turns them down however much you tell it to. If you find that your desirable audio never gets any quieter than -20dB, you can tell your noise gate to turn the recording down any time audio is not exceeding -25dB. You can even tell it how much to turn it down: all the way for a clean recording, or maybe just a little to allow some natural hiss in. The noise gate appears easy enough on the outside, but can be a little complicated to master. If your settings are too high, you will clip out parts of your recording, making it obnoxiously unlistenable
Feb 22, 2013 | Toshiba Computers & Internet
There is a short hiss sound almost like an air leak coming from the front drivers side wheel. Its not an air leak
CHECK THE TIRE AIR STEM.I HAVE SEEN THEM LEAKING.I HEARD A HISSING NOISE TOOK TIRE OFF SPRAY SOAP WATER SOLUTION ON IT LOOKING FOR A AIR LEAK.DID NOT SEE IT UNTIL WHEN I PUT HUB CAP ON.HOLE THAT THE AIR STEM GOES THROUGH HIT AGAINST AIR STEM HISSING GOT WORSER LOUDER THEN I FOUND WHERE LEAK WAS.SO CHECK AIR STEM TO TIRE MOVE IT A LITTLE SEE IF YOU HEAR HISS NOISE.
Feb 16, 2011 | Chevrolet Silverado 1500 Cars & Trucks
Power light comes on but no picture at all...
There are several more fuses in the TV, but they are not like the main power fuse. Most of of the time there black with and lead coming out of each end about the size of a resistor. I think there are 9 of them, you will need an ohm meter to check them and a soldering iron to replace them. Good luck Eric.
Jun 01, 2010 | Toshiba 57H82 57" Rear Projection...
Hissing noise coming from the rear of the car. I
probabbly not the brakes, maybe the tires but u need to check that, if u hear that noise with the engine running it might be a burned out gasket on your exhaust line
hope this helps
Nov 20, 2009 | 2003 Mazda Mazda6
My fridge says that its 'off' but when I push the on/off button it does not turn back on? All of the lights are on, but its not cooling. What should I do
Find out if the fan(s) and compressor are running when you push the "on" button. You should be able to hear them run as some are that noisy...if they run very quiet then put your ear near the rear bottom of the unit. You probably can see the small cooling fan blades turning at the bottom rear of the refrigerator probably on the right side where the cardboard cover has some cutout slits in it. If that is ok then listen carefully for the compressor noise. If it is actually pumping freon and cooling while running you will hear a slight hissing noise a little like water in a brook. If you hear a humm but no hiss then maybe the compressor is trying to start but can't. If that is the case you will in a short while hear a fairly loud click near the compressor which is the current overload tripping out. It shuts the power to the compressor off but when it cools it will reset itself and the compressor will humm again. If this is the case repeatedly and you do not hear the hissing of the compressor running you must unplug the unit and have it repaired since allowing the compressor to try to start numerous times can eventually cause damage. To make sure the compressor is trying to start you can also remove the cardboard cover at the bottom back of the refrigerator and place your hand on top of the compressor. You can feel if it is running plus it will get warm...even hot...if you can hold your hand on it while running and you hear the hissing noise mentioned above then you should be getting cooling. First thing to check if the compressor is not running is the start/overload unit that is mounted on the compressor..the old fashioned refrigerators used a real coil type relay to do this lasting over 40 years without need of repair but all refrigerators in these modern times got rid of the real relay and simply insert a very cheap disc type thermistor wired across the run and start terminals on the relay...this design of start unit goes bad very often and can burn off (melt) the compressor terminals and even catch fire. Many years ago I worked for Western Electric Co. in their thermistor area making these for the telephone company. They are fine when not subjected to high current but for the refrigerator they allow them to get really hot in normal use and they burn up. So, if that is your problem then replace the unit and you may be back in business...after you clean the dust off of the condenser coils at the bottom of the refrigerator...I like to use a leaf blower for this..does a great job quickly.
Aug 21, 2009 | Kenmore Refrigerators
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Rear screeching noise with 99 Honda Accord
your rear brake warning clip is telling you you pads are getting low only if you have 4 wheel disk brakes does this apply
Feb 14, 2009 | 1998 Honda Accord
Hissing noise in house
To solve this you are going to need to start eliminating things. You say you hearing is good, well just make sure next time you hear the hissing put your fingers in your ears to make sure it goes away. If it doesn't then it is internal i.e you have tinitus.
Next start turning things off at the mains. Your hifi can't hiss if it has no power, so try turning it off at the mains by unplugging it. If it is not your HiFi then start turning other things in your house off. Till you stop it.
Regards,
Andrew
Sep 13, 2008 | Audio Players & Recorders
RADIO SHACK TRC-447
A number of things....faulty speaker (you can scratch test this with a torch 1.5 volt cell....cell pos goes to 1 speaker terminal
and cel neg goes to other speaker terminal..you can conect it any way around with flying leads from the cell...just keep touching the terminal with one flying lead...you will hear a scratching sound in the speaker) have your mike checked...test the tx/rx relay on the circuit board for tx/rx switching, or, a failed
driver transister in the output stage....the list is many
Cheers flyingfox@people.net.au
Jun 21, 2008 | Radio Shack TRC-447 CB Radio
Samsung PCL542R 54" Rear Projection Television Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
