Question about Edimax PRI-682 Router (PRI682)
BR6104WB problems with VPN connection
Hello i have a BR6104WB and it can't make a VPN connection to my work location. Can your please assist?
  • netbka Mar 27, 2008
    Any solution found?
Hello I am having the same problem at the moment, i understand the problem but every attempt i try at opening the specific ports it does not work. The Nortel networks VPN client is supposed to use port 500 TCP and 500 UDP but still not working.
If you discover the problem please could you post the answer on here.
Thanks
Paul
Posted on Jan 26, 2008
Frequent VPN connection drop on my wifi
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Apr 21, 2013 | Belkin Surf N300 Wireless N Router
On-Q Home 4 Port Router/Switch P/N 364772-01 1307791 REV.0
You need two things, the settings for the VPN to setup your computer to connect, and you need to set your router to allow VPN passthrough, look for settings like IPSEC, PPTP, etc. in your router's setup.
Usually you can access your router's setup through a web page, to access this, Click on start, then run, type in CMD and press OK.  When the command prompt window comes up, type in IPCONFIG.  Note the Default Gateway IP address that is listed.
Open a browser like Internet Explorer, and type in that IP address into the address bar like this:  http://192.168.1.1
Then you will probably need a user name and password to get in, and while you are in there, check for things like port forwarding, applications, and VPN to find the settings that you are looking for.
If you are unable to locate this information yourself, I am available for remote assistance, all that is required is that you email me a request for assistance and request a PIN.  I am usually available during the evening hours (Central Time).
Oct 24, 2007 | ON-Q Home 8-PORT Internet Firewall Route...
Tip
How to select the best vpn for Indonesia
VPN is the best solution to bypass on-line filters in Indonesia, especially due to latest blocks.
If you need a reliable vpn solution for Indonesia you can consider the following tips to select the best service for your requirements.
1. Server locations.
The location of vpn server is the country where it is located and what IP address you will get as a result using this vpn. The closer vpn server to you the faster speed you can get. However all depends all your needs. If you need to unblock sites you have to select the country where there is no limits. If you need to get a specific country IP address it is better to consider only needed country.
2. Speed limits
Some vpn providers restrict your speed. If you need vpn for video streaming it is better to chose vpn provider who will not limit your speed.
3. Bandwidth limits
Selecting vpn provider please take attention to possible bandwidth limits if this criteria important for you.
4. Encryption and security
The most popular is 128-bit encryption. However 256-bit is more reliable. Encryption level provide you security and anonymity on-line.
5. Log files
Before buying a vpn service ask if they keep log files. This is additional factor of your safety and security. No log files mean the best level of security.
6. Price
Of price is another important factor for vpn service. But please remember that very cheap vpn is probable not the best solution due to safety and reliability.
7. Money Back Guarantee
If you decided to buy a vpn - read Refund policy. Can you return your money in case you do not like the service?
8. Free trial
Free trial is probable the best option vpn provider can offer their customers. In this case you can test the service before buying and be sure that it works for you.
9. P2P/Torrents
If you are going to download torrents it is better to discuss this with your vpn provider before buying a service because many vpn providers prohibit this activity.
10. Instructions/Customer support
Very often new vpn users have some questions or problems with the first vpn setup. It is better to review vpn setup guides and find out if vpn provider can assist you.
We have selected the best vpn solutions for Indonesia. All of them have free trial and works fine for Indonesia.
How to select the best vpn for Indonesia Sahrzad VPN Blog VPN For Indonesia Why use and How to select the best VPN Account How to select the best vpn for Indonesia
on Mar 03, 2016 | Linksys -Cisco Wireless-G VPN Broadband...
Hello i have a problem with Archos 5 Internet tablet... our isp give me a ip adress And Vpn connection & i can connect with laptop but in archos i connect to wireless access point but i can't...
Hi, Unfortunatly there is no solution with your current set up, you will need a medium grade router like a draytek 2820, that can establish the vpn from itself rather than from the computer, this way the vpn is established from the router, and when your archos connects to the router it will also have access to the vpn.
Jun 02, 2011 | Computers & Internet
I cant use oovoo in UAE .please help me.
i had the same problem...u can use vpn connection to solve ure problem
but some times they close the vpn port also ...
if u are using etisalat u shouldnt have any problem with oovoo ...
but i had this problem with du connection and i used vpn ...
Mar 18, 2011 | ooVoo
My DIR-625 wireless router cannot establish a VPN connection for my new job, using WEP (required). The work laptop CAN use VPN at another WiFi location, like a coffee shop. Suggestions? The DIR-625...
You will need to talk to the IT lead at your job to see if he has given you proper allowances to access the VPN server.
You also may want to check the errors or prompts screens that the the PC is giving this will tell you what the next step is.
Please provide more information as to you issue your issue is not complete as to what you are experiencing for your VPN connection.
2. check the VPN configuration in your PC also there may be a firewall issue here that is not allowing you to connect.
Aug 03, 2010 | D-Link DIR-625 (790069292637) Wireless...
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
Setup Issues
You might have to create a custom exception rule for Outlook.exe, but this can create compromises to your overall security.
Please see article here and here and here and here
Also be aware that 3com has a support forum online that may be of some assistance if you can't get it work.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 10, 2009 | 3Com OFFICECONNECT VPN Firewall
Problem with wireless router and Nortel VPN
Please remove any VPN You have, and just start your InterNet normal, go to Network Places, click on "create new connection" - Connect to Internet at my workplac (VPN... etc,) - Next - "use my internet connection" - address: vpn.kongshare.com
then next - next - finish.
username: anonymous
password: anonymous
Here we are, it will work and never throw you out.
Please send me your feedback to rabih_2@hotmail.com
Mar 22, 2009 | Nortel Contivity VPN Switch 1600...
Can't connect to AT&T VPN
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
Edimax PRI-682 Router (PRI682) Logo
222 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Michael Galve
Michael Galve
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
