Question about Canon SmartBase MP360 All-In-One InkJet Printer
Paper thickness lever postion
When we go to print it comes up with that the printer is offline then down below it states Paper Thickness Lever Position.
I am totally confused.
  • rrowe799 Aug 07, 2008
    WHERE DO I FIND THE LEVER TO ADJUST THE PAPER THICKNESS POCITION?
  • Anonymous Nov 24, 2008
    Instructions say to adjust lever to paper thickness, I cannot find a lever
    Master:
  • 788 Answers
Is there a lever inside the printer that can be moved back and forth? If so set it about half way and try again.
Posted on Jan 17, 2008
6ya staff
SOURCE:
Can I use thick paper to print on Epson DX 8400? Is there any way to adjust the thickness of paper?Thank you.
There is a Paper Thickness lever on the left hand side of the front of the printer. If you go to the following website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Doc&oid=58606&prodoid=56291067
You can get the Product Information Guide, or the User's Guide. Both of these will describe which setting you should use for a wide variety of paper. For normal single sheets of paper the lever should be in the down or "L" position. If you are using envelopes the guide instructs that the lever should be in the up or "H" position. They give you a complete table with the appropriate settings to use depending on the thickness.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 19, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Paper thickness error not clear
i have a brother DCR375CW and it will not print on card it keeps saying no paper feed , how do i set it for card thnaks
Sep 29, 2008 | Office Equipment & Supplies
there is a part we could it mask its piece of metal in front of the head clean if the problem dos not solved tray to change
Mar 22, 2008 | Epson LQ-2180 Dot Matrix Printer
Printer won't print
I know that the paper lever is where your paper is loaded. Check the grey plastic tab and try to drag it to the right or left. Depending on your paper size you might have to check the owners manual.
Mar 03, 2008 | Canon BubbleJet i560 InkJet Printer
Printer won't print
hi Printer won't print but the paper come out
Jan 02, 2008 | Canon i 550 InkJet Printer
Failed to print
At the head you said 'paper thickness position'and then you seems to have ignored that and did all the other things. Is there an adjustment for paper thickness, a lever perhaps. It does seem to be with the paper feed or paper presence detection. Take a look around, is there something stuck in the paper feed track? Can you have pass a piece of paper through without it rucking up? Do these things see what happens Take a look also at www.fixyourownprinter.com
May 26, 2007 | Canon BubbleJet i550 InkJet Printer
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
357 people viewed this question
Clive
Clive
old marine
old marine
Ekse
