Question about Dryers
Dryer won't spin
I have a problem with my dryer, the drum won't spin but there is heat coming from the element. I have tried taking the load of washing out but it still won't spin. I can't find a reset switch either. The dryer is only 5 months old but the online store where I bought it don't want to acknowledge responsibility. Any help will be appreciated thanks.
  • DAiello703 Dec 07, 2008
    I have an old )15 years or more) Kenmore heavy duty gas dryer, front loading. Model No. 87581800. I had it repaired a year ago and believe belts and things were replaced.
    Now when I press on the Start button the drum will not turn. There is only a buzzing sound.
  • Cobra8 May 07, 2009
    I have the same problem and the model number is kenmore 78702895. Your help and any suggestion is greatly appreciated.
  • 5,911 Answers
This may be a simple broken belt problem. The dryer utilizes a belt that wraps around the drum and is driven by a motor. If the belt breaks, the dryer heating circuits will still finction normally, but the drum will not rotate. It would be helpful if you could provide me with a model number (located somewhere around the door opening, or along the back of the operator console). If it IS a belt problem, this is a fairly inexpensive fix. If the motor, however, has gone bad, it may be considerably more. Please post back with your comments. I hope this helps you.
Posted on Jan 17, 2008
  • carolineturn Oct 21, 2010
    can it be fix on your own without paying some 1 to do it
  • terri bee Jul 11, 2012
    I have the same problem. Is there a site to tell me step by step?
My maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Oct 24, 2012 | Maytag Dryers
The dryer start and the drum spins around but there is no heat...I checked the circut breaker and everything there seems fine. I tried to take the back off the dryer check the heater but I could not get...
The element access is from a panel on the bottom of the front panel or you will have to take the front completely off which is a lot easier than taking the back off. The front comes off with just a few screws and the top may actually hinge back a little. The element should be at the right hand bottom of the dryer. You may visibly be able to see a break in the element coil .
Apr 14, 2011 | Maytag SDE3606A Electric Dryer
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Open Questions:
Dryers Logo
2,205 people viewed this question
Top Dryers Experts
