Question about Toshiba Satellite P25-S607 Notebook
Toshiba satellite P25-S607, DVD inside: Mashita UJ 811 doesn't work
Hi I opened up the dvd drive to follow a suggestion I found on line to fix it and two thin metal pieces came loose on the left, plus a spring. I seem to see where the pieces go (I think) but not the spring. Can't seem to find a schematic diagram when I google which is all I would need to see where the pieces go. Can't even seem to find a generic diagram. Can anyone help? Thanks
    Sergeant:
  • 239 Answers
Http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=438069&rpn=PSP20U&ct=UG&soid=470129&BV_SessionID=@@@@1849588803.1200582589@@@@&BV_EngineID=ccccadeddfdjedicgfkceghdgngdgnn.0
Here is a phone number too (800) 457-7777. Try that and also maybe the spring you are talking about came from the locking switch on the bottom under the bay, Check that and see if it still springs back for you, Hope that help you out somewhat. Thanks Bear001
and(800) 457-7777.
Posted on Jan 17, 2008
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
How do i replace harddisk in my toshiba p25 s487
Ensure you have your backups up to date and either OS disc or rescue discs to place a new system on your new hard drive.
Remove the larger cover from the underside of the laptop, slide out the hard drive. Remove the old drive from the cradle and fit the new drive to the cradle. Slide it in.
Power the laptop up open the DVD drive and place your restore/PS disc in it and on the bios menu select F12. Set the boot device to DVD/CD.
Boot from the DVD/CD drive and follow the prompts.
When finished, download updated drivers from www.toshiba.co. and restore your backups and programmes.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite P25-S487 Notebook
Toshiba satellite 5105-s607 insert system disk error. Every time put o.s disk in keeps saying same message.
Log into the bios and change the boot order to boot from the CD - it will then boot up your CD system Disk first
As the PC boots - you should see a message to get into bios/setup usually F10, F2 or del key varies buy manufacturer
then look for the bios section for boot order and make sure the CD/DVD drive is set to before the harddrive
Mar 19, 2010 | Toshiba Satellite 5105-S607 PC Notebook
I have a Toshiba P25 that does not detect the dvd drive. The drivers have been downloaded
Maybe your operating is got missing windows files for the dvd drive try to repair the windows that you are using then try and see whether it appears or go into CMOS and check whether detects it
Dec 03, 2009 | Toshiba Satellite P25-S487 Notebook
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
DVD RW
I can not give you a YES, but I've found TOSHIBA CD/DVD compatible with Compay/HP provided the connections and size are the same - not the otherway round though .....
May 07, 2008 | Toshiba UJ-820BTJV-A (K000015860) DVD...
Screen dosent display
if your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
Nov 01, 2007 | Toshiba Satellite P25-S607 Notebook
Console button(s)
First u need to repair ur OS
Oct 25, 2007 | Toshiba Satellite P25-S607 Notebook
Toshiba Satellite P25-S607 Notebook Logo
193 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
