Question about Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter
Adam 4520 cable link to modem Multitech MT5600BA
I try several cables but I cant get conection from modem identified above thru Adam 4520 to de equipement,however if I get conected thru PC to Adam 4520 the acess to the equipement is granted.
So I think I,m need de pin out cable to link de Adam 4520 to Modem MT5600BA.
Can you help me?
  • Brett Duxbury
    Brett Duxbury Jan 15, 2018
    Hi tonitono, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    If it is serial what is the number of stop bits and parity error checking and baud rate required by the modem ?
    Have you set up these in the adapters settings ?
    RS232 cable being used ?
    9 pin or 25 pin ?
    Is the cable correctly wired ? (null modem cable won't workhttps://en.wikipedia.org/wiki/Null_modem...
3 Suggested Answers
6ya staff
SOURCE:
Mike McWhinney
  • 537 Answers
SOURCE: Advantech ADAM-4520 Serial Adapter
The ADAM-4520 is a converter between RS-232 and RS-485/RS-422
Look on this link for the FAQ for the ADAM-4520
http://www.advantech.com.tw/support/sr_detail.asp?SR_ID=1%2D1ZFWI0&SEARCH_TYPE=FAQ
But to answer your question about converting from 9,600 baud to  19,200 baud, I'm not sure I understand. The device should support those data rates. It all depends on what you need to do.
Posted on Oct 30, 2007
Anonymous
SOURCE: I can't use two adam modules with a 4520, help!!
Do the addresses conflict?
Posted on May 29, 2008
How to fix code 0000001C
Windows update install a driver but is not working, when i try to make a scan it says that it is not conected when is already conected. CanoScanLide 25
Jun 19, 2012 | Dell Inspiron M5110
I conect zte modem with laptop . laptop is shown runtime errer
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Aspire 4520 - Above keyboard right below the power button, the far left one is the wireless button
Aspire 5310/5315/5710/5710Z Series - Row of switches above keyboard deck, left most switch
May 28, 2011 | Computers & Internet
I have a new belkin n150 when i conect to the modem, there is a amber flash light for the modem on the router, when i conect the computer directly i have conection, i have folowed all the instructions but...
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
Feb 21, 2011 | Belkin N150 Enhanced Wireless Router...
How to conect a wireless router to a regular modem
If your modem/router has a USB connectivity, you can connect it via USB. Else you will have to buy an Ethernet PCI Card, which wont cost you much.
I hope this solves your problem. Good Luck ! Kindly Accept my Solution.
Regards, Arjun
Apr 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cant get to connect
need to add a dns server address 4.2.2.1 and 4.2.2.2 located in local area conection
Sep 08, 2008 | Arris SURFboard SB4200 Modem
Not conection!!!!
Try turning off your cable dsl modem and restarting it. Many isp's use dhcp to assign IP addresses, your router may not have been assigned one if the modem hasnt been restarted. Also try powering on in this order: Modem, router, pc.
Feb 11, 2008 | Linksys Wireless-G Broadband Router
My connection fall
Please describe the leds in front of the modem which led lights or blinking ?
Aug 17, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Advantech ADAM-4520 (ADAM-4520-D2) Serial Adapter Logo
240 people viewed this question
Top Advantech Computers & Internet Experts
 Mike M
Mike M
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
