Question about Motorola Mobility RAZR V3i Cellular Phone
Bluetooth I recently repaired my V3i because it got wet. Now everything works fine except the BLUETOOTH. It is unable to find any devices in a room full of possible connections. Do I need to replace something or can I fix this problem with a Flash or Flex...?
  • 170 Answers
Bluetooth uses a technique called spread-spectrum frequency hopping. It changes frequencies 1,600 times every second. A frequency of 2.45 gigahertz (actually between 2.402 GHz and 2.480 GHz, to be exact). For the bluetooth device to work at 100% it needs to be 100% compatiable. More than likely, if you change your earpiece device, you should be able to pickup your songs. If you go to the VerizonWireless website, they should have 100% compatiable devices. 1.yep simply attach the cable start your motorola ponetools and tada you are done 2.pleace select your bluetooth in your menu and you see bluetooth turn on for fuw minits or scoend set it for long time
try to use the service after removing the memory card and than try, if the same problem presist than the problem is with the BT connector, it will be solved by any local vendor nearby u, and if it works after pluging out the memory card than format the memory card once and than try...... take the bacup of ur data first.
Posted on Jan 17, 2008
    Brigadier General:
  • 7,752 Answers
What you need to do is take your phone to a service center and have them reflash the firmware, that will correct the bluetooth problem.
  • Sylvester Brathwaite
    Sylvester Brathwaite Sep 13, 2008
    it can be fix with a firmware upgrade or reflashing the phone a flex will not work as that deals with the keypad only.
Is it possible to replace or repair the touchscreen?
Possible but may not be cost effective. Internet search for the part number on your screen is your only hope on this one.
Apr 19, 2016 | Kenwood Dnx9990hd 6.95" Touchscreen...
I need to connect a bluetooth to my razr
Do you need to connect a bluetooth headset , or do you need to start bluetooth file transfers?
In either case, to activate blue tooth on the RAZR V3i go to settings>connections>bluetooth (May appear as "bluetooth link") > hands free> look for device. The Razr will scan for other bluetooth devices. If you need to send files over bluetooth, turn on the blue tooth antenna, and navigate to the files you wish to send. Press the menu button, and press "copy" and select the device you wish to send it to in the devices list. If there is no device, or the device you with to send it to is not in the list, press "look for devices".
Mar 28, 2011 | Motorola Mobility RAZR V3i Cellular Phone
I cant listen to music connecting my bluetooth
check out that is the phone's bluetooth is properly paired with the bluetooth headset if not check it
or
search for the bluetooth devices from the search list of the bluetooth devices in the bluetooth menu of your phone
Mar 09, 2009 | Motorola Mobility RAZR V3i Cellular Phone
V3i as bluetooth modem
update the firmware then try again
Aug 25, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth link busy
Try it with another BT and see if still shows the same.....if it does, then you might need to reset your phone....refer to user manual on how to reset phone. And if it worked fine with another BT device, then you might want to exchange/repair the jawbone....try this first, drain the battery completely from the jawbone, then recharge it and try to connect after charging..
Best of luck....
Jul 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Bluetooth handsfree problem
Todays Tivia:
Why is it called Bluetooth?
Harald Bluetooth was king of Denmark in the late 900s. He managed to unite Denmark and part of Norway into a single kingdom then introduced Christianity into Denmark. He left a large monument, the Jelling rune stone, in memory of his parents. He was killed in 986 during a battle with his son, Svend Forkbeard. Choosing this name for the standard indicates how important companies from the Nordic region (nations including Denmark, Sweden, Norway and Finland) are to the communications industry, even if it says little about the way the technology works.
Oct 20, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Bluetooth connectivity
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device. My question for you is, what kind of device are you trying to connect to?
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Problem with the bluetooth on my motorola v3
HOPE THIS HELPS: http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
Mar 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3i Cellular Phone Logo
69 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
