Question about HP Photosmart C6180 All-In-One InkJet Printer
Scan to pc
Hi
I have installed the software about 4 months ago and have just tried to use the scanner. however, i don't seem to have the scan to pc option on the menu - the only optioons are scan to reprint and scan to memory device which is a bit of a hassle.
Whilst 'fiddling' with it there was a message to install, however when i insert the cd nothing happens.
As you can guess I am not a pc wiz so your help would be very much appreciated.
thanks
TC01
  • leismom Jan 23, 2008
    I have a similar problem with the printer. When I try to scan to pc, I don't have a list of pcs on my network. What I have gotten, however, is a list of software programs which are on my computer. If I pick on of them and scan to it, the printer scans, but no document shows up on the computer. I have used the solution from HP and ensured that all the appropriate .exe files are on the list of exceptions for the firewall. Other than that, it says to make sure that the files have full access and then to open up specific UDP and TCP ports on the firewall settings. Looked that up on Microsoft and their directions do not match what I see when I check my firewall settings to "add port". Frustrating. The scan to pc function is one of the reasons I got the printer.
  • danski Jan 26, 2008
    I am having a problem when I try to scan anything to one of my computers.. print works fine, but when I try to scan from the computer there is an error that tells me to restart the software (yea right - done that been there still won't work) when I try to scan from the all-in-one (all-in -none) it says no scan options..... what's up any fixes?  please advise
    President:
  • 4,402 Answers
Posted on Feb 08, 2008
6ya staff
SOURCE:
Epson v300
Make sure you have Adobe acrobat or similar installed so that you have PDF available on the PC. It may also be in the software for the Epson. I had a scanner a few years ago whose software excluded PDF and I ended up installing new software of a generic printer / scanner to use Adobe PDF
Jun 07, 2012 | Epson Perfection V300 Film Flatbed Scanner
I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
May 13, 2011 | Computers & Internet
Hi. I bought an Epson Stylus TX210 printer not to long ago, and it was working fine. Everything except the scanner. so, my parents and I were trying to fix it and I'm not sure what we did wrong because...
im not sure what i'm and doesn't means
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options you can troubleshoot
hope this helps
Apr 17, 2011 | Computers & Internet
Scanner doesn't work. It says no scan options,
You can check if the scanner driver is still installed by going to Control Panel\Scanners and cameras (if you have windows vista, you need to be in "classic view" in control panel)
If you see the HP scanner listed there, you can double click on it to run the windows scan wizard.
If this works you just need to find some scanning software, not necessary the HP one.
If there is no scanner listed, you will need to download the software and drivers which you can most likely find on the HP website.
Mar 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I SEEM TO HAVE 'NO INK' IN MY TABLET PC INPUT PANEL PROGRAM
In the programs that don't work, check your ink settings. Mine kept going to white until I got them set to black as default.
NEVER use system restore unless you have already tried malware scans, spyware scans, virus scans AND registry repair programs to fix software related problems. It is a LAST RESORT ONLY, just like FORMAT C.
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
Scanning to import to a computer
Normal 0 The best way to scan images to save on your computer is touse the scanner software on the computer. Not the scan function on the scanner.
You don't say what type of scanner and software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned.
Jan 29, 2009 | Office Equipment & Supplies
Cannot install printer/scanner
Forget the CD, you can download all necessary software from here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&lang=en&dlc=en&product=374584&
Also, although I'm not 100 certain, I think that you should first uninstall psc 1317, disconnect it from PC, install software and than connect it to PC. Trying both ways won't hurt for sure. ;-)
Apr 20, 2008 | Office Equipment & Supplies
HP OFFICEJET J5740
you probably don,t have the correct or all of the drivers installed.
The second possibility, is the software scanning program.
You could try 1 called paperport.
Hope this helps [email protected]
Feb 20, 2008 | Office Equipment & Supplies
Scan to computer
When you installed your printer, it came with software for your computer. It should have placed HP icons on your desktop. Click the one that says HP Solution Center and then select Scan Document. Follow the steps from there.
Jan 17, 2008 | HP Photosmart C6100 All-In-One Printer
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
HP Photosmart C6180 All-In-One InkJet Printer Logo
75 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
