Back to:
Tags:
Whirlpool GS6NBEXR Side by Side Refrigerator
Whirlpool refrigerator water dispenser not working (by 12 users)
posted by MIKEBLACK45 on Jan 17, 2008
I have a Whirlpool side by side model ED22TQXGN00 with a thru the door water/ice dispenser. The ice maker is working fine but when I depress the adjacent water lever, I hear a humming noise but no water comes out. Can you tell me what part needs to be replaced? I have replaced the water inlet valve in the past when the ice maker wasn't getting water, so I hope that is not the problem. Could it be the bracket control (Whirlpool part number AP2988571)? I appreciate an email response to me at Michael.D.Hauser@BGE.com One last thing, can you explain how I can remove the front panel to get access? I'm told that it's easy to break and expensive to replace.
Comment by MIKEBLACK45, posted on Jan 18, 2008
dvdpartsguy- If the water inlet valve is bad, would the icemaker still get water? I would think that there would be problems with both. I appreciate your response.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
11 Other Users Have The Same Problem
Comment by chefmoey, posted on Aug 07, 2008
I have the exact same problem and I've looked over the entire panel looking for access to the inside of the front door panel.
Comment by atherj6, posted on Jul 27, 2008
same problem: ice is fine but no water
Comment by cyclesblood1, posted on Apr 12, 2008
I have the same problem. If I hold the cup in place the water will come out after about 30 secs.
Comment by Guest, posted on Apr 01, 2008
My Whirlpool refrigerator door ice maker dispenser does not work. The light does not turn with a good bulb and its seems no electricity is flowing through. The ice maker inside the freezer is operating well.
Comment by jpva, posted on Feb 17, 2008
how to get the face plate off. I've done nothing. I'm afraid it will break
Best Solution
posted on Mar 03, 2008
FixYa! (100)
Ariesgod
Rank:Apprentice Apprentice
Rating: 100%, 6 votes
If you are still curious as to how to remove the face plate... There are 2 small slots on the bottom of the faceplate. Pry out on those and the plate slides up and off from there.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Whirlpool refrigerator water dispenser not working:
I don't want to Accept this solution
Solution #2
posted on Feb 09, 2008
FixYa! (100)
Guest
Rating: 0%, 0 votes
My ice dispenser lever stopped working. I took the face plate off by first removing the tray, grabbing the bottom face plate and pulling straight back. I found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. I'm ordering a new bracket that holds the switches. Hope this helps.
Thank You!
Solution #3
posted on Jul 11, 2008
FixYa! (100)
fretmonger
Rating: 95%, 3 votes
I too found that the internal switch was displaced because the retention pins (plastic) were broken. This caused the switch to be set back from the dispenser arm. Bad bad design!
Instead, I replaced the pins with screws.... never coming apart again. Now how long before the Ice side breaks?!?!?!?!
Thank You!
Solution #4
posted on Jan 17, 2008
FixYa! (100)
dvdpartsguy
Rank:Wiz Wiz
Rating: 89%, 23 votes
REPLACE THE VALVE AGAIN.
Thank You!
Can you Help with these Refrigerators problems?
Whirlpool GS6NBEXR Side by Side...
I have an reverse osmosis system. I don't need the...
Can you tell me exactly where you ordered your part and...
The water tube on the dispenser drips. The dispenser is...
My ice maker will not make ice. The tray is full but it...
messed with the valve but water still runs freely to the...
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 16, 2008
My water starts and then stops after a few seconds. How can I fix?
Comment by Guest, posted on Feb 15, 2008
Ice dispenser on 4 yr old whirlpool fridge works,water has completely stopped. Any suggestions or remedy to this problem?
Ice dispencer on 4 yr old whirlpool fridge works, water has completely stopped. Makes NO NOISE, nada, zippo, zilch! Any suggestions or remedies to this problem?
Comment by em-tee, posted on Jan 28, 2008
I have the exact same problem. The water dispenser just stopped. The lever apparently doesn't do what it is supposed to do. I can't figure out how to get the face plate off (although the thought of using a jig saw keeps hovering at the edge of my mind).
Anyone who knows (1) how to get the face plate off by a non-destructive method and (2) how to fix the problem once I do, please, please post.
Comment by ptcollins, posted on Jan 21, 2008
I have a Hotpoint HSM25GFRE-SA refigerator with a water dispenser problem ... ice maker & water connection from the wall works fine ... never had a problem until last week when it just stopped, no slow flow, just all of sudden, it stopped. I thought it might have been my water filter required changing, which I did, but still no water. Any suggestions?
Comment by notsogoood, posted on Jan 18, 2008
THe water dispenser doesn't work. It got slower and slower upon activiavtion, now it does not work at all. help
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
