Question about HP Photosmart C6100 All-In-One Printer
Scan to computer
I have set up my c6100 and whilst all the other functions work I don't seem to be able to scan to pc. I only have the 'scan to reprint' and 'scan to memory device' options.
Any ideas?
Thanks
TC
  • 4 more comments
  • Anonymous Jun 22, 2008
    Exactly the same as the guy who brought me here
  • raycanderson Jul 21, 2008
    It was working on my old xp system but when I went to vista home, it does not work. I downloaded the latest driver, but still can not scan to my computer.
  • Anonymous Aug 24, 2008
    Any ideas?
    Thanks
    TC
  • JNABaker Mar 07, 2009
    I have the same problem -- no "scan to computer" option on the Scan Menu on my HP 26100.
  • Anonymous Mar 09, 2009
    HELP ME!!!!
  • Anonymous Mar 14, 2014
    I have tried scanning with the L7680, but I don't think I know how to do it.
When you installed your printer, it came with software for your computer. It should have placed HP icons on your desktop. Click the one that says HP Solution Center and then select Scan Document. Follow the steps from there.
Posted on Nov 17, 2008
The following patch solved this problem I had for 6 months. Conlict between scanner & tablet. I can't believe HP is not advertising this more visibly on their web site
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=cj-64024-1&lc=en&dlc=en&cc=us&lang=en&os=2093&product=1153494&ts=true#thankyou
Posted on Dec 07, 2008
Hi Guys!
Did any of you find the solution for this problem? Becos I have the same problem too!!!
Posted on Aug 25, 2008
When I went to use my HP C6100 scanner for the first time I received the message, "No Scan Options; Refer to device documentation to trouble shoot." Can someone please tell me what I am doing wrong and/or where to find the "device documentation' ?. Thanks.
Posted on Apr 03, 2008
  • 625 Answers
I have an hp all in one 5160. When I set up to scan, on computer it asks what to save as. I choose .jpg to a directory on my desktop. Options on the scanner bed is "scan from glass" #1 so it saves the pix on my computer desktop folder.
Posted on Jan 17, 2008
Where do I look to find the solution? Must be somewhere to click, but I can not get my eye on it.
Posted on Jul 21, 2008
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Hi i just cant fix my problem with scanner i got HP Color LaserJet 2820 and if i want to scan it says not set up on pc but its there. Pls tell me step by step how to solve this i use printer through...
The quick and easy solution here is not to scan from the front panel of the unit.
Use the HP Solution Center from the PC to initiate the scan and it should work perfectly.
In other words, put the document(s) in the scanner or document feeder, then go to the computer, launch the HP Solution Center, and use the scan function there.
It's actually more versatile anyway and gives more scan options with regards to quality, file type etc.
The Scan-To-PC function from the front panel can be tricky to set up at the best of times.
If you absolutely must be able to scan from the front panel, I suggest paying for a chat session or phonecall, because there's going to be a lot of back and forth discussion to get it set up right.
Apr 27, 2011 | HP LaserJet M1522nf Multifunction Printer...
Scan won't work to a computer. How do I set up "scan to computer"?
Make sure your computers set up with the correct drivers for your printer. You can download them here http://welcome.hp.com/country/us/en/support_task.html just type your product name/number and search Then you can use mspaint to import the image using the scanner. Open paint from start, all programs, accessories, paint. Make sure you have your document in your scanner and go to file in paint and select from scanner or camera.
Mar 03, 2011 | HP Photosmart C6100 All-In-One Printer
I have a HP photosmart C6100 series printer I need to scan to a pdf file
First open the Solution Center then click on Settings >> then click on Scan setting >>> then click on file type and select it as PDF and click on okay and then close the solutuion center and reopen and try to scan
Jul 31, 2010 | HP Photosmart C6100 All-In-One Printer
I can not scan it says it is not connected to a
What OS are you using? Did you try a new cable or switching ports? (If a USB device, are you attached via a hub? Try directly connecting to the computer.) Did you install the software before connecting the all-in-one to the computer or did you let the OS find the drivers? (If you use the default driver, you get a printer only with Windows.) Is your all-in-one supported by the OS? (I don't see any drivers for the C1600 itself on HP's site. If you recently updated to a new OS, those buttons may not work if the device is sufficiently old.) Can you scan using the software on the computer instead of the on-board buttons? If you have the device plugged into a print server (on a router, for example), you can also lose the scan functions if you lose the bi-directional information transfer.
I hope these ideas help.
CIndy Wells
Mar 11, 2010 | HP Photosmart C6100 All-In-One Printer
Wireless set-up. I can print,scan and print & scan to a storage device but cannot scan to the computer
The HP All in Ones require that you install and run the suite of software to set up computer scanning On my all in one, the message says, you must install the drivers to do this. The suite of software is on the CD. It is also available through HP.com
Make sure you download the full software suite from their website or your CD.
Dec 18, 2009 | HP Photosmart C6100 All-In-One Printer
Hi, My HP m2727 AIO is not working properly. Specifically, there seems to be a problem with the scanner function. Each time I key in "Scan" I receive a "cannot detect" message.
Hi Cheryl,
If you are scanning from your pc and seeing this error message it could mean that your scan drivers are disassociated. If you have multiple multi function printers or scanners that could be causing the problem as it creates a conflict with the software framework. I would recommend uninstalling the software as well as any other multifunction and reinstalling the software as well as the additional product software.
If you are scanning from the printer it may not be set up and you would have to set up scan destinations.
Al
Eliteprintersolutions@gmail.com
Aug 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Photosmart c6100 all in one
Are you having this problem when you are using the buttons on the front of the printer? Have you tried directly clicking on the HP Solution Center icon on your desktop, and scanning from within that program?
Jul 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
1,472 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
