Question about Creda W120VW Front Load Washer
Creda excel 1200
My son has just been given a creda 1200 but the front cover has been removed and there 3 black wires from it do you know in what order and where thay go
cheers
Paul
  • bioeng Jan 18, 2008
    Hi Washdoctor the wires are fixed to the switches thay have been taken out of the black plug that fits to the bottom of the PCB
    cheers
    Bioeng
  • 139 Answers
Yes on these three wires you will see if you look carefully that they have written on them neutral ,, one ,,, two,,
these wires connect to the buttons on the front panel,, So if you find the one that says neutral on it... that one connects to the switch on the left hand side of the switch,, its the side that has a connection to the other switch by a small metal strip usually (but some times a wire connection is used ) the other wires connect to the other side of the switches number one connecte to the top switch and number 2connects to the buttom switch i hope this helps....
any probs let me know...
Posted on Jan 17, 2008
I have a creda excel 1200 the other day the water started to come out of the door and it tripped the electric,anyway i now managed to drain some of the water out of the machine but now its still tripping...
Remove back from machine, dissconnect motor plug from motor, then turn machine on, if electric trips then you know motor is ok so place plug back into it, then do pump, and so on untile something is disconnected and fuse wont trip. Make sure you do not have machine connected to power supply while removing wires, also that wires do not come into contact with anything when disconnected. And dont remove Any earth wires
Feb 11, 2010 | Creda W120VW Front Load Washer
I have a Creda 1200 washing machine, I am unable to locate the fluff filter. Does my machine have one? if not, what happens to dogs hairs etc? will they damage my machine?
The filter is at the rear of the washer.
Remove the lower rear cover of washer.
Remove the large black hose fastened to bottom of drum.
Clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well..
Please rate my solution.
Thanks.
Jan 17, 2010 | Creda W120VW Front Load Washer
Electric circuit diagram needed
I am afraid that you can not get a wiring diagram for these washers, the only chance you have got is to contact Hotpoint/creda and see if they have a service manual for sale.
Go to www.hotpoint.co.uk
Plz rate my solution.
Thanks
Jan 23, 2009 | Creda Washing Machines
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Creda excel 2000 skips spin and rinse cycle
The filter is located in the sump hose at the rear of the washer.
Remove back panel and undo the clip that holds the large black hose onto the rear of the drum .
Inside it ,you will find the filter.
Remove and clean.
Plz leave feedback for this solution.
Thanks.
Dec 14, 2008 | Creda W120VW Front Load Washer
Creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Apr 17, 2008 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
299 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
matt
matt
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
