Question about Xerox Phaser 8500/DN Printer
Error message 07,010.43:41188
Printer will not display any other information other than this error message. Any ideas?
  • 2,072 Answers
That error message means that the print head is not moving properly from the home park position to the print position.
Here are the mose likely possibilities.
1 Ink has spilled out and into the stainless steel block that the print head pivot shaft goes through. With the covers off looking from the front it is on lower left about mid machine, about 1 inch square. Would most likely have yellow ink in it.
2. You had a power failure or unpluged the machine without powering it down properly and the Print head wiper is tacked to the print head not allowing it to move.
3. One of the cables that are connected to the print head are keeping it from moving properly.
4 The Media motor gears are out of timing. That is not very likely though.
Also, to prevent this, you need to be sure the machine is level front to back and side to side.
I have seen one print head defective leaking ink into the bottom of the machine making a huge mess.
But that code is definatly related to the print head not being able to pivot freely.
Posted on Jan 17, 2008
I have an error message 0060 on my HP Inkjet 8500a Wireless with a error code 0060 message. No idea what to do. Any ideas please
Please perform the below steps..
  1. Power Off the printer.
  2. Power Off the Wireless Router.
  3. Now Power ON the printer and check if error message is displayed. If error still exists, it could be a printer issue and printer needs to be serviced. Call HP for further support.
Jun 13, 2011 | HP Office Equipment & Supplies
CLX 2160 Message: Deve Home Sensor Error. What can i do to correct it.
There could be two problems
A minor error occurs and the machine is waiting an error to be cleared. Check the display message, and solve the problem referring to Understanding display messages, see page 11.3.The toner cartridge is low. Order a new toner cartridge; see Ordering supplies on page 12.1. You can temporarily improve print quality by redistributing the toner. See page 10.4.
For referring this page numbers, please download the manual from this link.
The error message, which you have told me, not in the error message list. I think there is an internal failure for the printer. It is always recommend servicing your printer with authorized service centers. If the error message is not in the error list, owner cannot repair but, technician can repair the printer. I hope this information is useful for you. Thank you.
Apr 19, 2011 | Samsung CLX-2160N All-In-One Printer
Printer error on Tektronix Phaser 860dp
Hi juniorgona:
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Hope that this helps.
Apr 08, 2009 | Office Equipment & Supplies
My printer is a Lexmark T 630's on your display an error message "202 paper plunged back tray open" and that has no role and no arrest or plunged ajunde please me..
Could you list all of the values you see in the secondary error code? You can see the values by doing the following:
1. Press and hold Return and press Select to enter for sub error codes.
The first screen of information displays. Write down the information.
2. Continue pressing Return and Select until each screen of information is obtained.
3. When the last screen displays, the original message displays.
Feb 19, 2009 | Lexmark T630 Laser Printer
Dell a960 50c error on cartirdge error message ..nothing seems to
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 17, 2009 | Dell A960 All-In-One InkJet Printer
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
Error code 6500
This is caused by the information in your registry. Please refer to the following link and download the Advanced Windows Care ... you will not be disappointed ... Scan with AWC and try your printer again. The message displayed is an error, I am supposing.
May 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Can't find what displayed error message means
This is normally down to the information or data if you will that you have sent to the printer. Delete all in the print que and restart the printer.
If this doesn't work then tun the printer of and remove the additional memory. Turn on and tested again.
If still doesn't work then problem is with the printer formatter board the firmware is corrupted or the board is faulty either one is a hp repair or a second hand machine.
I do hope the first two help you
Thanks J
Jun 07, 2006 | HP LaserJet 9500n Printer
Can't What displayed error message means
49 error normally means that the information sent to the printer is corrupted clear the print que shut down printer and restart. If problem still there then shutdown the printer then remove one of the additional memory turn back on if still same problem repeat removal of the next memory replacing the one you have just removed and so on. After you have done this and you are still getting the problem then it is 99% certain that the printer system firmware is corrupted or the formatter control board is faulty.
Thanks J
Xerox Phaser  8500/DN Printer Logo
120 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
