Question about Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard
Strange rectangles on startup
I Have a Strange Problem The PC has been working fine all along then when I changed the IDE Cable for the DVD Rom and Turned the computer suddenly it displayed small attached rectagles with different colours all across the monitor some are flashing some not. even when I revert back to the old IDE cable, or to any other for that matter, it just keeps doing the same thing Please Please help Iam Desperate here
regards MUSA
  • castatroy Jan 25, 2008
    Thanks Benimur
    But even when I plug the mboard on its own with only the monitor and power supply plugged the problem persists. The mboard has builtin video, I have also tried to change the RAM modules still, any other suggestions? I have yet to try the cleaning though, thanks
    regards
    musa
  • 63 Answers
The problem come only after you change the ide cable, so hi chances that when you insert the ide cable into the Mboard, too much force causing the Mboard pcb trace open cct. Mean you need to replace the Mboard. hope it help.
Posted on Jan 25, 2008
    Brigadier General:
  • 6,966 Answers
Verify that all cables, connectors, components and devices are where they should be and fitted snugly to their mate/counterpart.
It could either be you video or your memory. If your PC has a built-in video then it is in all probability the memory. Either way, try removing and cleaning the gold contacts/pins using a pencil eraser. Thereafter clean the slot(s) where they are inserted using a clean paint brush or a disposable toothbrush. When reseating/re-inserting, pls make sure that you hear an audible click/snapping sound that assures you that the component was placed back in properly. At other times, wiggling the memory (or video card) a bit also helps.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 17, 2008
  • Louie  Role
    Louie Role Jan 25, 2008
    Hi again musa,
    Since you have tried with just the MB, the PSu and the monitor and still it doesn't work, then you already have narrowed it down to just 3 possibilities.
    Assuming it powers up, the fan at the back of the PSU spins and the lights on the front panel light up, then the PSU can also be eliminated leaving just the MB and the monitor.
    1. Try using a different monitor (though unlikely) to verify that the monitor is not the one in question;
    2. On the motherboard, try doing a CMOS reset. Normally there is a 3 terminal jumper close to the battery. Moving the jumper to the other pairing temporarily will reset the CPU. You need to move it back to the original position for the unit to operate.
    3. If this still fails, perhaps you have to try to clean or replace the memory.
    If that still does not work out, am afraid something like what emme have posted is the reason.
    Pls post back for anything.
MY ROM is a Sony (DDU1632C1) Internal DVD Drive. It doesn't read the DVDs and the CDs. I checked the data cable from the mother board and the power cable, cables worked for my CD rom but not the DVD/CD...
Check On the Back Off Your DVD-Rom itself look little pin with a black connector like a mini bridge... Look if it on position Master If So change your little connector to Slave Position.. The Restart your PC... Check also your IDE Cable for defect and all the pin inside your DVD connection ...Good Luck
Oct 09, 2010 | Sony (DDU1632C1) Internal DVD Drive
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
I can't fing my 2nd cd rom in my pc anywhere.
The good thing is that you have power to the drive. Is it a SATA or IDE drive? Have you checked that the cables are fully seated on both the drive and the motherboard?
If it is an IDE drive, is it on the same cable as another drive? Did you set the jumper to match the master/slave connection of the cable? Consult your manual if needed. Most of my IDE drives actually have the jumper labels on the back of the drive (next where the IDE cable plugs in). There are 3 options - cable select, slave and master. I've never had much luck with the cable select jumper option.
If it is a SATA drive, you might have a bad cable.
Mar 06, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
DVD-CD ROM not working
change the cable on it ide cable dust out case inside relly well get all dust out clean cool ok change ide cable if not buy new dvd rw drive
Jan 16, 2008 | Compaq Presario 5000 PC Desktop
Motherboard can not detect dvd rom help
try changing cable is it set at master on jumper for end of ide cable and if its middle dvd rom drive its slave set jumpers to slave ok try changing cables clean yo cd
Jan 09, 2008 | ASUS K8V-MX Motherboard
HP dvd rom disabled
if you can open your desktop..try to replace the ide cable of the DVD/Cdrom it might be deffective.before you open your pc just make sure that the power is off.after changing the ide cable of your dvd the system will automatically detect your drive.if you got same problem again try to consult your hardware vendor to claim your warranty parts and service.good luck
Dec 03, 2007 | HP Media Center m7060n PC Desktop
CD/DVD ROM disappears
I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
Intel Desktop Board RC440BX (KRC440BXPAK10) Motherboard Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
