Back to:
Tags:
Hotpoint Aquarius WD63 Front Load All-in-One Washer / Dryer
Dryer not drying - also lets in water (by 4 users)
posted by Gav01 on Jan 17, 2008
Hi, please can some one advise me if they have a solution. Recently my dryer has started letting in water during the drying cycle on my WD63.
What do you think the problem is?
Many Thanks
Comment by Gav01, posted on Jan 27, 2008
This does not occur when it is off on mine. The wash cycle is fine, however when i try to do a usual dry cycle (either straight after wash or seperatlaly) the clothes come out hot and wet and i can hear water in the bottom of the drum.
Comment by Gav01, posted on Feb 04, 2008
Anybody come across a solution yet?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by nicky c, posted on Jan 31, 2008
I have the exact same problem. Unfortunately I have just moved into a new home, the machine was already fitted within the ktchen units and there is not a manual. Is there supposed to be a vent pipe or is there a condenser tray I should be looking for. Were does all the fluff go if the dryer does the job like a convention dryer.
Comment by unikey, posted on Jan 21, 2008
same problem here, only when using the dryer no water when off and intermittant
tia
Simon
Comment by Beckwith, posted on Jan 20, 2008
I have the same problem. There is no problem when the machine is off - it does not fill with water. It is simply that at some point in a drying cycle of any length the clothes will become soaked. This used to happen occasionally but now occurs nearly every drying cyle.
Best Solution
posted on Jan 17, 2008
Helpful (85)
WASHDOCTOR
Rank:Guru Guru
Rating: 88%, 171 votes
does water also come in when the machine is off, if so then a solinoid at the back where the hot and cold water pipes connect to it...
However i need more information to give you a perfect solution...
hope this helps get back to me if it dont ill try my best...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dryer not drying - also lets in water:
I don't want to Accept this solution
Solution #2
posted on Feb 06, 2008
Inappropriate (40)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
me too me too me too
Rating Locked! (?) Gav01 has rated this solution as Inappropriate
Thank You!
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WD63 Front Load...
there is no heat during the drying
Hi machine stuck on rinse hold and mini wash with lights...
my machine dose not work on the wash cycle, spin, soak,...
hotpoint washing machine wf645a 1400 spin keeps flashing...
i have a washing machine from hotpoint WD440 when i turn...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
