Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Dryer not wrking - letting in water
Hi, please can some one advise me if they have a solution. Recently my dryer has started letting in water during the drying cycle on my WD63.
What do you think the problem is?
  • Gav01 Feb 11, 2008
    thanks, i'll get back to you
    Scholar:
  • 90 Answers
Does the water come in all the time? If so turn off each supply line faucet to identify which line is leaking and take that valve inside the washer apart and clean it out, if not completely replace that module. Let me know more about what exactly is going on.
Posted on Feb 10, 2008
2 Suggested Answers
  • 139 Answers
SOURCE: Dryer not drying - also lets in water
does water also come in when the machine is off, if so then a solinoid at the back where the hot and cold water pipes connect to it...
However i need more information to give you a perfect solution...
hope this helps get back to me if it dont ill try my best...
Posted on Jan 17, 2008
Dryer not drying cloths even though it does the full cycle? hotpoint wd63
There are several reasons for this to happen.
  1. Heater element faulty.
  2. Thermostat faulty.
  3. Heater relay faulty.
  4. Blocked condenser.
  5. No cold water going in on drying cycle.
You really need a meter to test the components with, to get the bottom of the problem.
Please rate my solution.
Thanks.
Nov 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
Problem during drying cycle
THERE COULD BE TWO POSSIBLE TYPE OF FAULTS FIRST IT COULD BE A FAULTY HEATER THERMOSAT.SECOND THE HEATER HOUSING UNIT MAY NEED TO BE CLEAN OR THE TIMER IS FAULTY
Apr 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Jan 17, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryer letting in Hot water
Have made suggestion on later note.
Jan 14, 2008 | Hotpoint Aquarius WD63 Front Load...
Not draining after cycle
try checking the filture on the front at the bottom of the machine they some times get full of muck
Jan 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD440G
I SWITH ON THE MACHINE AND F 01 APPEARS
Aug 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Problem with our washer/dryer
sump/filter is blocked instead of flushing on dry cycle is filling as not pumping well. ring hotpoint to reorder pts cheaper then anyone
Jan 06, 2007 | Hotpoint Aquarius WD63 Front Load...
WD63 Drain during wash but not dry cycle
the chances are you water valve has gone the drying cycle requires water to convert steam back to water, or poss your condenser is blocked this cant be cleaned easily better to change I dont know how competent you are if you have a muti meter you could test the soleniod which should have a resistence of around 3800 ohms. the valve is a triple one and the one that serves the condenser is the one facing downwards, disconnect power,take back off, turn water suppy off,take the 2 leads off the bottom solaniod only ,put your meter on contacts make sure you have selected crrect range on meter ie:10mohms if 0000 solanid faulty.Change valve if reading says 3800 valve ok change condenser
Aug 01, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
