Question about Samsung SC-D363 Mini DV Digital Camcorder
Samsung sc-D363 I charge my battery and left it in my camcorder and when I used it it work for a while but later on a message in my screen says eject taoe
  • 3 Answers
I had the same problem. The batteries do not last. When the battery becomes weak it can not run the tape so it tells you to eject it.
Buy a new bigger battery. I bought a 160 for ~$30.
Posted on Jan 31, 2008
My SC-D363 will not recognize the SD Memory Card.
The SC-D363 only can handle up to a 1 GB SD memory card, no larger, so if you are not using a 1 GB or smaller card, then that is your issue.
Jan 17, 2013 | Samsung SC-D363 Mini DV Digital Camcorder
My samsung camcorder keeps showing eject when i try to record
Possible that the mode switch is jammed or the eject button is jammed. It can also be that the drive had not completed and so urges the motor to eject so as to complete the loading. failure of sensors cannot be ruled out.
Jul 19, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
I charged battery for 1 day but my camcoder no power. if the battery is bad how do i know? please helps.
If the camcorder will power up with the charger plugged in, it is most likely the battery. Depending on use, rechargeable batteries can go out in as little as 6 months.
Feb 06, 2010 | Samsung SC-D363 Mini DV Digital Camcorder
Eject
i need this program
Att.
George
Oct 09, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Oct 03, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
I have vertical multicolor lines
I think u are using pre recorde cassetts that were recorded on any other camcorder..
Samsung D363 supports ntsc not pal....
and the cassetts recorded on pal must have prob with ntsc based device...
all u have to do is record cassette with the same and then test playback...
Feb 25, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 won't charge battery
well , just make sure that the camera is set to the off position when charging , otherwise i dont think it will charge properly.
hope this helps
Dec 18, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Eject button
meriann,
The eject buttons are not typically available seperate. I've checked other sources such as ebay and pronto as well, but they turned up nothing. Rather than voiding the warranty of the camera by disassembling it, use the warranty and argue with samsung that the fault in the eject button is their responsibility, and i don't see why you'd have to pay for the repairs, as long as the camera doesn't show signs of it being dropped.
Hope this helps :)
Nov 22, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Can't Install Video Codex? Why Not?
This sounds like a device-driver problem. The camcorder will never be recognized by your PC until you get the right driver and then the 'Mass Storage' msg will go away.
Vista is too new for the D363. Check the Samsung website for a Vista driver for USB.
Nov 17, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
