Question about Canon PIXMA iP1600 Printer
Hi i need help with printer problem
My canon i865 has a colour problem..it doesnt print the colour i want...its like it doesnt show magenta?
    Sniper:
  • 60 Answers
Your printer works with the BCI-6 cartridges, that are in fact just ink-tanks, the printhead being apart of the tanks.
So if the cartridges are not empty, it cannot be because of them.
Did the printer worked fine at the beginning, or is this an initial problem?
If the problem occured just a while ago, you should consider that NOT PRINTING a long time (30 days) with a printer can lead to ink drying out in the printhead, clogging the nozzles. If you have some tehnical skills, you can remove the cartridge and desassembly the printhead (where the cartridges are in) and do the following:
Put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the printhead with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridges back on the printhead (without installing it in the printer), rap it in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles.
Get the cartridges again out of the printhead, install it in the printer, then install the cartridges again and run a few cleaning processes from the printers maintenance software.
It should work. If you dont have the tehnicall skills needed, Canon gotcha, or you can visit a local specialist to make all this for you, they usualy have better equipmens, as ultrasonic cleaners and special solvents that makes all this easyer.
Rate the solution if it helped you!
Thx.
Posted on Jan 18, 2008
6ya staff
SOURCE:
I have a Canon MP560 and when I print red text it appears as pink/purple colour. Is there a way to adjust this setting?
There is no adjustment to printing coloured text. This is rather unusual. I feel you maybe using recycled cartridges and the magenta is not true magenta. I once bought a couple of so called magentas and they turned out to be orange!!
Jun 20, 2011 | Canon MP560 All-In-One InkJet Printer
My MP 145 Canon cannot print red colour, but other colour are fine, what should i do? thank you
Check the Magenta cartridge, is ir empty?
Do a maintenance head cleaning (do a deep clean) - check the Magenta print head, is it still blocked.
Oct 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon i865 - black print is blurred/fuzzy on every 3rd line. Have done clean, deep clean, changed both 3 and 6 cartridges. No problems until recently. Beautiful full colour photographs clear and sharp,...
Your printhead has burned out nozzles, the black is the most used and first to go. It switches nozzles during printing for even wear, that's why every few lines you get bad spots.You need a new printhead.
Aug 07, 2009 | Office Equipment & Supplies
Cannon i865,(no colour printing)
Hi all of you
you have to open the printer setting dialog box , thereby a check box set it off.
Hope this fix your problem
thanks
Hamedo
Nov 21, 2008 | Canon Office Equipment & Supplies
Ip5000 printer
This could be down to None canon carts clogging the head up or clogging the purge unit up, If they are all canon carts it could still be down to the print head, if not it could be down to the Logic Board. At the worse case it could be down to both printhead and Logic Board
Hope this helps
Oct 20, 2008 | Canon i850 InkJet Photo Printer
Magenta ink ran out,continued to use printer,replaced ink tank twice,have done cleaning & deep cleaning several times no magenta coming through,all other colours ok. what to do next?? anybody have...
Think you may have killed your print head, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jul 01, 2008 | Canon Office Equipment & Supplies
I am trying to print a full colour picture on a canon i865; the picture only prints in green(and black). How do I get it to print normally as it used to?
is your magenta color cartridge is out of ink or your magenta head of dried up clean it with nozzel cleand option from your printer maintanance software.
Jun 03, 2008 | Canon Office Equipment & Supplies
Canon PIXMA iP1600 Printer Logo
Clive
Clive
old marine
old marine
Ekse
