Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
OE error message
Keeps showing error message OE
  • Anonymous May 25, 2008
    OE error message
  • Anonymous Apr 29, 2009
    Mu machine keeps stopping and giving me an OE error, any help would be appreciated
    Genius:
  • 1,003 Answers
REPLACE POWER CONTROL BOARD
Posted on Jan 18, 2008
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Machine keeps shuting down with message OE. Have
You should have an error code legend in your owner's manual. Check to see what "OE" relates to on the washer. If not in your manual, you should be able to determine what the code relates to via LG's website. You may need to contact an appliance service company.
Feb 20, 2010 | LG Washing Machines
MAYTAG NEPTUNE ERROR CODE OE
The "oe" code indicates a water pressure problem. Remove the water supply hoses and check the small metal screens inside the water inlet valve. Make sure they are clear of rust or debris. Check the water inlet valve solenoids. They can can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid I will attach a photo for reference. Hope this helped and best wishes.
Sep 11, 2009 | Maytag Neptune MAH9700 Front Load Washer
Outlook express
hi,
Error 0x800c0133 when you are retrieving email with your Outlook Express (OE) is because of currupted Inbox file.
To remedy please follow these steps:
  1. Open OE, on the left pane, right click "Local Folders", select "New Folder...", specify a name for your new folder as "Temp".
  2. If you are still able to access "Inbox", move all mails in "Inbox" to the new "Temp" folder.
  3. Go to menu "Tools" -> "Options" -> "Maintenance" tab -> "Store Folder" button. It will show the location of your Inbox file, please remember this location.
  4. Close OE, go to the location mentioned above, delete the file "inbox.dbx".
  5. Restart OE, the "Inbox" folder should be auto recreated. Move back your mails to the new "Inbox", remove the "Temp" folder.
or
Another solution
Error Number:0x800c0133
Error Number: 0x800C0133 = a corrupt Inbox.
Move any mail you wish to save to a local folder you create. Then:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3 the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked.
Apr 16, 2009 | Microsoft Windows XP Home Edition
Message OE
OE : Drain Hose is Kinked or clogged or The Drain Filter is clogged - Clean and straighten the drain hose / clean the drain filter.
also do check for the pump blockage.
for more info on this check the following link
http://pastoralfarms.us/2008/04/21/lg-fl-washer-2277-oe-error/
Dec 23, 2008 | Washing Machines
LG Dishwasher
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
i just about blew $1500 on a new machine !!
Jan 17, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
292 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
