LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
Problem for LG 24 in. LD-12BS6 Stainless Steel Free-standing...
LG Dishwasher
By lg fan on Jan 17, 2008
keeps showing error message OE
Same Problem
May 07, 2008
-   IT HA OE MESSAGE.-   Guest
Mar 18, 2008
-   Yes, I too am getting the OE message on LG model LD-14AT2 dishwasher. How expensive is a power control board? Is there anyother reason for the error message?-   Guest
Jan 20, 2008
-   MY LG DISHWASHER IS SHOWING THE OE CODE AFTER A FEW MINUTES INTO THE CYCLE....-   BRADLEY47
Solution #1
posted on Apr 21, 2008
Somewhat Helpful)
carb
Rank: Apprentice
Rating: 80%, 4 votes
OE means outlet error- Pump check that you can hear water pumping first if not check your drain lines for obstructions
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 15, 2008
Very Helpful)
lynchie
Rank: Apprentice
Rating: 100%, 2 votes
ok. our machine has done this for 6 months or so, it was ok for the 1st 6 months. i have checked and cleaned and unblocked and gone bloody crazy. today i found the fault and fixed quickly.
the installer stuffed up. the waster water hose must head up and be fixed just under your bench top, then come down hill to your exit/spiggot/drain attachment.
ours was just lying more or less at floor level coming up to the spiggot. so whenever the waste water pump switched off, water would run back into the machine, hence the OE error, and also dirty water with food would then get chucked around it what should have been a clean rinse.
a diagram of the waste water house and how it should be done is in the manual.
i just about blew $1500 on a new machine !!
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Jan 18, 2008
Not Rated)
courtdate
Rank: Wiz
Rating: 85%, 742 votes
REPLACE POWER CONTRL BOARD
Was this helpful?
Yes
No
Popular Solutions for LG 24 in. LD-12BS6 Stainless
Questions and Unsolved Problems for LG 24 in. LD-12BS6 Stainless
Do you recommend LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher?
Answer
Answer
LG LD12AW2 DW contiunes to fill and I can't fo the life of me locatse the filler float assy and... (More)
Answer
I have the same problem OE error code. I pulled everything apart. I have checked pump,lines and all... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
