Question about Miele Cat & Dog 326i Bagged Canister Vacuum
Wiring diagram I havea Dog and cat appart and are trying to understand the wiring. From the power side I have a black then another black for a individual terminal each and 2 x blue coming from a single terminal on the 3 pin plug side. This is passed thruogh the switch to a 4 x pin terninal strip that has a brown yello blue and blak from top to bottom. Can any body help me with a wiring diagramm so I can traced these wires?? The problem with the vacuum is that the motor is not running. I am trying to determine (with the use of a miultimetere) if power is getting to the motor.
    President:
  • 1,673 Answers
Check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often.
Posted on Jan 17, 2008
6ya staff
SOURCE:
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
Wiring diagram
First check the cord to make sure you have continunity throw both leads, check them at the cord reel, there are 2 wires hooked up to it, if not then the cord is bad. Check the swith also, the next cause would be the speen control mounted on the motor, part #04416342, sells for around $85. If your motor checks ok, then it most likely the speed control, they go out quite often...Thank you
Regards!!!...
Jul 24, 2008 | Miele Cat & Dog 326i Bagged Canister...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
Ametek wiring diagram for a Oreck XL21 600 ECB
I cannot find a wiring diagram from where I am located right now, but I do know that the black wire coming from the power cord goes to the top side of the motor when you have it laying upside down with the cover off, and it will go to the tab towards the back of the vacuum. Sometimes they put a black dot beside the tab and if that is there you put your wires from the power cord on those. You will also have two wires coming from your light bar in front and the white wire will usually have a piggy-back terminal that your white wire from the power cord attaches to as well. If there are no black dots beside the terminal tabs the white wires will connect to the bottom terminal on the opposite side from the black power cord wire. It will usually be on the lower side of the motor as well. The black wire from the light bar will go on the remaining terminal tab as there is usually only three tabs on the motor. I will check back later this week to see if this has helped you and if not I should be able to get a diagram this weekend.
Sep 22, 2013 | Oreck Vacuums
Miele 5000 cat and dog power cord will not retract
Hi There,
I have made a video showing how to get a miele S5311 apart. Most of the machines in the same series use a very similar procedure so take a look at the video it should help you.
Mar 13, 2013 | Miele Vacuums
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele Cat & Dog 326i Bagged Canister Vacuum Logo
375 people viewed this question
Top Miele Vacuums Experts
Colin Stickland
Colin Stickland
Gerry Harvey
Gerry Harvey
Chris Nomland
Chris Nomland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
