Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Need the driver for sata driver pavilion dv2519
Ineed the driver for pavilion dv2519tu for windows xp actually preloaded vista was came my mechine, iwas formated harddrive but it was not recognised hdd please help me.
thanking you in advance.
  • asly101 Feb 03, 2009
    i have dv 2519tu laptop but,i have problem to install xp which is hard disk not found so please help me
  • 70 Answers
Check cable connection loose contact both data and power
reconnect it replace cable if necessary
Posted on Jan 17, 2008
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
When i am installing windows xp on Hp pavlion dv3 laptop following error occurs "A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER IF THIS IS THE FIRST TIME...
Since, for your laptop you are downgrading the operating system from Vista to XP then with HP notebook.
You need to disable Native SATA support in BIOS utility and go ahead with the installation. To disable the SATA support you need to follow the below steps:
== Disable SATA native support:
1. Turn on or restart the notebook.
2. Press the F10 key when the "HP Invent / Compaq" logo appears on the screen. This will open the BIOS menu.
3. Select the "System Configuration" tab.
4. Select "Disabled" for the "SATA Native Support" item.
5. Press F10 to Save and Exit. Choose Yes for "Save configuration changes and exit now".
For more information on this visit the below link from HP.
Problems with SATA Drivers When Downgrading From Vista to XP
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01675438&cc=us&lc=en&dlc=en
if you get any problem while doing this then plz get back. Actually you need to do lot of things to downgrade from Vista to XP on HP preloaded vista operating system.
Let me know if you find any difficulties doing this..
I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | HP Pavilion Dv3-1075us Notebook
How to get software for downgrade from vista basic to xp sp2 oper
first you download a sata controller of your hdd because winxp sp2 will not support a sata controller after you finesh download the sata controller copy the installer of windows sp2 then compile it again to gother sata contraller. or just download a windows sp3 has updated inculded sata controller that is the easy process
Mar 04, 2010 | HP Pavilion dv6000z Notebook
Installation of windows xp on a preloaded windows vista laptop
See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
Then it will detect your drive and install as normal :D
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Help me to install WinXP in a Gateway Laptop that came with SATA HDD
you have probably already fixed this but maybe others can find this a little helpful. i had to downgrade a gateway ma7 for one of my customers who had lost their recovery cd with vista on it. Their HD had gone bad.
The reason the XP installer says "no HD" is because the the drivers required by the gateways Sata controller (hd controller) are not preloaded on the xp install disc. The only way around this is to download the windows xp compatible sata drivers from gateways website and then slipstream them into a custon windows xp install cd. its actually not as difficult as it sounds. just download the sata driver, a slipstreaming program called nlite.
1 download and install nlite
2 put in your xp install cd, and run nlite, when nlite asks, browse to the i386 folder (your installation files)
3 you will have lots of options to choose from, but for this purpose, choose "add drivers" and select the location of the gateway drivers (c:\cabs\something) i think.
4 finish and burn the cd. then use it to install windows xp.
this little guide isnt step by step, but with a little trial and error you should get by
-Nele, MCSE
Jul 19, 2008 | Computers & Internet
HP DV2700Tx Windows vista to XP Downgrade
you will need to download the SATA controller driver from
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&cc=uk&lang=en&os=228&product=3641490&dlc=en
without that your laptop won't recognize your hard drive there
are 2 ways to solve this:
first one you'll need an external floppy drive save the sata driver on a floppy put your xp disk in and start the install at the very begining xp prompts you press F6 to install sata driver press that and it'll get the driver from the external floppy drive.
second way is to create an xp disk with the sata driver to achieve that you'll need a deployment software i use nlite
http://www.nliteos.com/ if you have any problems add me to your msn messenger atlascomputerrepair@hotmail.co.uk and i'll talk you through it
May 03, 2008 | Panasonic U7500 Notebook
Hp530 software from vista to xp
hi there,
it seems that this particular message can be related to problems with drivers being loaded. so i guest is u are using a xp cd with SP1 try a copy of XP Pro SP2 included .... also check out the ram on your system... ddat could be a bit of a problem also....and last ... in Bios change hdd from AHCI to IDE mode ... xp has a bit of a trouble seeing sata drive
Apr 08, 2008 | HP Pavilion dv6000z Notebook
How to install driver in preinstalled vista in notebook OR download xp driver
No vista drivers will not be supported. Recently i did the same thing and ran into troube getting back to vista. Your best bet is to download software updates that are compatible with vista, most things are now. Or if you want to install something if you right click the intall file first and got to properties, then compatibility and change it ro run in xp sp2, apply, ok. see if this helps
Dec 06, 2007 | Microsoft Windows XP Professional With...
How to burn a bootable xp cd with sata drivers slipstreamed into it
I have never used this utility but Bootdisk.com has a solid reputation, for $4 US get access to his special utilities.
FResh XP install With SATA ---- SATA1 fresh install of XP using WIN98 and SATA drivers Seems like it will install XP with SATA drivers and then you can see your hard drive.
Nov 08, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
60 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
