SOURCE: turn off power and reinstall the jumper in normal mode position
Some MB's have a second jumper setting on the board to allow a technician to jump to a faster "trouble shooter" configuration. After any or no changes are made to the BIOS's configuration the BIOS wants the The tech to reset the jumper back to "Normal Mode" so the customer doesn't have an overclocked or "hyper"machine voiding it's warrantee. I have seen this on some mostly older boards including Intel's who are known for down speeding their MB's. Check the websit for the MB's manual and see if it tells you where the jumper is located. If not, Also try to update the BIOS to the latest version and this may resolve your problem. Hope so.
If I understand what you are asking: The computer starts up and you see the setup page. It then says that you are supposed to place the jumper in the normal position. It happens every time. The jumper is at correct position
Try to clean the pins on the board, check the connection inside th jumper. (with multimeter or else). Try to clear the bios .
SOURCE: turn off power and reinstall the jumper in normal mode position in intal(lga775)
if this message is appearing on your screen then the bios jumper is installed at reset position. so please install this bios jumper of your motherboard and the pin number 1-2 position of bios.
it will be allright
i get jumper the error massage is " Turn off power and reinstall the jumper in normal mode position
What your question?
