Question about HP LaserJet CM1015 All-In-One Printer
HP CM1015 copy/scan problem
My CM1015 not always, but often, produces only a completely black copy print, or sometimes a small strip correctly printed and the rest black. The same problems exists with the scanner. Sometimes, changing the BW threshold helps, but that option is not available with the copier. Printing is fine. Any ideas?
  • msbray Jan 18, 2008
    There is no problem with the cartridges themselves as the printer works perfectly - it's just the scanner/copier modes. Thanks for responding!
  • 89 Answers
If it printing fine it is more likely the scanner that is failing.
Posted on Jan 18, 2008
    Problem Solver:
  • 5 Answers
DO THIS CHECK WHERE THE CATRIDGES IS IN ORDER.OR IF IT IS LEAKING
  • faith muthoni Jan 18, 2008
    it is ok if it is the model of a printer then what was your suggestions.
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Why my HP color laser jet cm1015mfp all in one not installing correct with my laptop win 7 64bit
According to the HP website:
"The Universal Print Driver (UPD) for the HP Color LaserJet CM1015 and CM1017 Multifunction Products might not be the best driver choice for this product because UPDs are typically print-only . There are no product-specific Windows 7 print/scan drivers available for this product.
While these products do not have a Windows 7-specific solution, you can run the HP product software created for the Windows Vista operating system on a Windows 7 PC in compatibility mode to enable full product software functionality.
This is the recommended Windows 7 solution to obtain the most software features for the HP Color LaserJet CM1015 and CM1017 MFPs."
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c02047129-6%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
May 25, 2014 | HP LaserJet CM1015 All-In-One Printer
I have recently replaced my black toner in my HP Laserjet CM1015 MFP and now I cant get anything to print? other toner colours are low but haven't given me a low warning so a bit puzzled why I can
Check and make sure the toner is in correctly. Also go to your start menu if you are running windows and look for your print settings print a test page if this isn't working then please message back.
Sep 25, 2012 | HP LaserJet CM1015 All-In-One Printer
Everything was working perfectly with my HP CM1015, I now have a new computer Windows 7 32 bit Home Premium and Microsoft Office Professional 2010. All my folders have been copied on to my new computer...
First here is the lnik to the drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1846081&prodTypeId=18972&prodSeriesId=1846080&swLang=8&taskId=135&swEnvOID=4062
However when you go to print go into the printer driver properties and confirm the driver is set to print in color. Most HP color machine drivers have a automatic and manual option with the driver, which allows or restricts printing in color.
Oct 21, 2010 | HP LaserJet CM1015 All-In-One Printer
Can not take colour print out, black colour printing is alos not very sharp, left side printing is very dull
problem with drum unit. sometimes unit comes with cartridge and sometimes as a maintenance kit.
Jan 15, 2010 | HP LaserJet CM1015 All-In-One Printer
Copying and scanning don't work but produce all-black image
please clean the scanning glass and also the feeder.
Open the machine check if any paper has struck anywhere inside.
In most of issues it will work, if this does not works call your technician to troubleshoot the problem
Jan 13, 2010 | HP Photosmart C7280 Printer
Black strip on right side when I copy
Check in your user manual how to reset the printer to factory default. This should clear up your problem.
Oct 09, 2009 | HP LaserJet CM1015 All-In-One Printer
HP LaserJet CM1015 All-In-One Printer Logo
613 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
