When I try to install Ad_Aware I get "Error 1720" and then "Internal error 2753". Of course the program does not install. How do I fix this problem?
Murray
it sounds that your were infected by virus, u cannot install that unless remove any variant on it.
The risk solution; is to remove your hard drive and connect to the other computer that has a potent antivirus.
after removing virus you take back your HDD then fixed back to original.
If this will not help, Your system was destruct by a virus so better backup your files and format and install fresh windows this fixed all errors.
If you don't want to scan the system maybe you should directly reformat it and reinstall windows.
Any problem arising thereto you can notify me for further instruction.
This is mozilla thunderbird. Inbox won't hold any more messages. I deleted some, but I don't see...
(More)
This is mozilla thunderbird. Inbox won't hold any more messages. I deleted some, but I don't see any tools or edits that will let me compact folder.
whnever i press send after getting a fax ready or if i try to open the outbox in winfax an error...
(More)
WHNEVER I PRESS SEND AFTER GETTING A FAX READY OR IF I TRY TO OPEN THE OUTBOX IN WINFAX AN ERROR MESSAGE APPEARS AND WINFAX SHUTs DOWN. I HAVE TRIED TO REINSTALL IT BUT IT DOES THE SAME THING.
I've been using STOPzilla antispyware, currently the scanner is unable to operate. I was told by...
(More)
I've been using STOPzilla antispyware, currently the scanner is unable to operate. I was told by their technical support staff that it is due to an infection from a rootkit. I downloaded and installed SOPHOS rootkit detection and removal, but while it is scanning the HKEY_ USERS registry file, the scan stops and the program shuts down.
