Question about Loewe Aconda ACO9303 30" TV
Speakers external to internal for Loewe Planus PLA 530
Hi
I recently removed my external speakers that a friend had installed for me. How can I get the TV to play through its own internal speakers. Is there a switch in one of the menus? I've confirmed that it's not muted. I can't get sound for my DVD player or my cable television
  • Loewe Master
  • 5,138 Answers
Go to menu turn internal speakers on also look on back of set some have a switch for ex&in speakers move switch to in, if this does not fix problem you may have bad audio output ic.
Posted on Jan 17, 2008
INTERNAL SPEEKERS do not work external speekers work when pluged in
Check the menu. In almost flat panel tvs there is setting that allow you to select in between internal speaker and external speaker. If the selected setting is external speaker the you wont get sound from the internal speakers.
www.electro-medical.blogspot.com
Sep 01, 2015 | LG 55GA6400 55" LED TV 1920x1080, 120 Hz,...
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
No sound on monitor tv. Does it have internal speakers or does it need external speakers hooked up to it? Also, i need help configuring it so it will play audio
Set indicated here has speakers and may have a slide switch on rear to select internal or external speakers.
Also in menu look to see if speakers are switched off.
Apr 03, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
The internal speakers don't play. Have been using external speakers now what to use internal speakers. I think there is setting wrong any indeas
Hello Dear,
I am well pleased to contact you after viewing your profile,which really interest me to communicate with you as a genuine friend, this is my e-mail address (aw.sesay@yahoo.com),
i wait to hear from you soonest.
Awa.
Aug 04, 2010 | Hitachi 57G500 57" TV
Speakers are not working
try these. remove ac adapter and battery. press and hold on the power button for 15 seconds. plug back ac adapter and battery. download the latest bios for your system from the manufacturer's website. if still same problem try a system restore from the time when everything was working fine. try an external speakers check if the audio jacks are working. if all fails replace mobo. if external speakers ok then replace laptop internal speakers.
Apr 03, 2010 | Computers & Internet
Need Help with Souround Sound 5.1
Double check your TV settings and ensure that you have your audio set for internal and not external. The external setting would only be used if you have external speakers connected.
Aug 08, 2009 | Audio Players & Recorders
I hooked up my stereo amp to my external speakers that were also still hooked up to my tv. now I don't get any audio from my tv just a high pitch sound. Is this an easy fix?
Hi, I can help. It sounds like the TV internal speakers were turned off so that the only speakers to have sound were the external ones. Go to your menu and find the sound area. There you can tell the TV to send sound to the internal speakers once again and not to external.
Jun 21, 2009 | Televison & Video
External speakers
Unfortunately no. The Panasonic PT-60LCX64 TV does not have any jacks, plugs or external connection point to attach he wires of external speakers.
Alternately however, it is possible to install 2 pairs of speaker terminals on the backboard and wire them in parallel to the internal speakers.
Hope this be of help/information. Good luck and kind regards.
Feb 05, 2008 | Panasonic PT-60LCX64 Television
Loewe Aconda ACO9303 30" TV Logo
209 people viewed this question
Top Loewe Televison & Video Experts
Computer Repairing
Computer Repairing
Jerry Umali
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
