Question about Brother IntelliFAX 560 Plain Paper Fax
Brother fax 560
My fax copes/or faxes only one-half (left side) of any document. i wiped the scanner glass and the rollers. but nothing changed. any ideas?
  • 1,003 Answers
Replace fax
only one side of scanner LED IS WORKING
Posted on Jan 17, 2008
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Lines on fax going out, fine receiving fax
check the scanner glass under the cover where the documents are fedd through if you lift the lid on this you should see a thin slip of glass if this has ink or usually tipex on it the lines will be on every fax that goes out.. there might be a small roller over this that has a clip each end you can take this out for acces to hte glass
Jul 31, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 560
Open the document feeder and look for debris on the scanner glass.
Nov 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Black line on all faxes I send to recipients
open the document feeder and look for wite-out on the small scanner glass.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
Brother 560 manual
Go to Left click on SUPPORT. From the SUPPORT OPTIONS list, left click on MANUALS AND DOCUMENTATION. You can then download the manual for your product.
Aug 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Line on fax when sending or coping.
Open the document feeder (the keypad assy) and look for wite-out on the small scanner glass.
Aug 03, 2008 | Brother IntelliFax-4100e Fax
Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually  it is that the problem. use windex to clean it.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Changing the CIS scanner
First remove the scanner control panel. pry the hinges out slightly and you can take off the control panel, then there are 4 or 5 screws and the top comes off. The 2 long rollers come out too. move the clip and slide them to the right. The scanner is the 3/4 inch wide 8 inch long scanner. ( the glass that reads your faxes to send ) It is coonected with a flat cable. It pops up when you push the clips holding it down. Lawrence
Mar 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Black line need help
where you insert the drum, look in the machine on top there is a glass wipe it
Jan 22, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 560 Plain Paper Fax Logo
57 people viewed this question
James Cagle
James Cagle
Jim Keysor
