Question about Acer Aspire 3680 Laptop
Frozen screen While I was attempting to watch a movie online, my screen froze, and I cannot make it go off. I tried ctrl+alt+delete, I tried pressing the power button, and even closing the computer, but when I opened it back up, its still on the same frozen screen, what do I do???
  • xanvians Jan 17, 2008
    well, as much as I did not want to do that, it was my last resort, and I suppose I will do it, thanks for the advice
    Genius:
  • 1,003 Answers
Unplug ac adapter and remove laptop battery for five minutes and put laptop battery back in and then check to see if that does it
Posted on Jan 17, 2008
Screen freeze
Press and hold the power button for 5 seconds and it shoild shut off.
Jan 15, 2014 | Fujitsu LifeBook Computers & Internet
Booting problem
Restart your computer
have a close look at the screen it will be quick you will see which key to press to enter bios
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
others you might try
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Sep 27, 2012 | Sun Blade 2500 PC Desktop
I'm locked out forgot password
If you can tell me what the Os do you use, it could be must better.
On XP you can try this:
Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
On Win 7 or Vista:
Ctrl+Alt+Delete won't work, you have to use some windows password reset tool. I recommend Windows Password Reset.
Resource: http://www.windowspasswordreset.net
Aug 01, 2012 | E-Machines EL1333G01w Desktop PC with AMD...
My Cruz tablet is frozen. I was watching a movie, and it froze and won't shut off. I have tried turning it on and off. Nothing happens. One of the frames from the movie is frozen on the...
There is a Reset Hole between the Power Button and the USB port
you need to press inside the hole with a paper clip and hold down until the tablet resets
Its labeled B on the diagram
Jun 23, 2011 | Computers & Internet
Dell Dimension 5150. After bost my computer, I can the accounts icons on the screen, but I cannot slect the icon by mouse because all USB port did not work.
You can try this. On the log-on screen where you see your Account Icons try pressing ctrl alt delete. Some windows XP are configured that if ctrl+alt+delete are pressed on the lon-on screen the classic log-on screen window will appear, where you can type your username and password thus eliminating the use of the mouse.
Jun 20, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a HP Pavillion dv9500 series. One night i tried to watch a rent movie, at the first 10 mins of the movie the screen frozes, alt+ctrl+delete doesn't work so i pushed the power button and then when...
If the Computer turns ON and the CD/DVD drive gets power then first, remove the disc from the drive. Then, turn off the Computer, disconnect the AC Adaptor, remove the Battery pack and clean the metal contacts on the Battery and in the Battery compartment.
Next, press and hold the power button on the Computer for 30 seconds.
Then, reinsert the Battery pack in the Computer then connect the AC Adaptor and turn the Computer ON.
This will resolve the issue.
Good luck!!!!!!!!!!!!!!!!!!!!
Oct 25, 2009 | HP Computers & Internet
Cant reboot - it started when the internet froze and i did ctrl atl delete and ended prosces for expoler, then computer froze so i used ctrl alt delete to restart computer, when computer restarted it...
Good day sir/maam, the reson why it froze is caused by a bad memory module, you may need to replace it. Open up your computer and locate the memory modules, remove all memory modules and bring it to a computer vendor for testing. or if you have the cash, better buy a new one. make sure that what you install on your PC be it tested or new is good.
Sep 27, 2009 | Dell Dimension 2400 PC Desktop
Cursor frozen and cannot cut the computer off or move the cursor
Ok try to boot in native DOS if the unit still froze. If it froze then check your memory card, reseat or clean it with soft eraser only its edge connector. Do this when battery is disconnected and no any other power source is connected to the unit.
Then if it run native DOS. If you can backup your important files, installation code. This will end restoring your unit to restore factory, do you have your restore disc?
Or you can try first to run in safe mode/repair options. Check if it can do some system restore.
May 15, 2009 | Compaq Presario 1200XL104 Notebook
My Satellite A40/A45 Series won't boot up.
If NTLDR is missing, you will need to do one of two things:
1) follow this link and follow instructions to create a NTLDR boot disc and get back up and running
or
2) boot to Windows CD and repair Windows installation
Hope this helps - remember to rate :)
Sep 25, 2008 | Toshiba P000392200 - Satellite A40, A45...
Acer Aspire 3680 Laptop Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
