Question about JVC AV-48P575 48" Rear Projection HDTV-Ready Television
Pretty sure this is the right model
I am looking for some good picture settings to make it look good and for some reason the bottom of the screen is slanted from right to left
  • ricsir Aug 19, 2008
    how do you replace the tubes, jvc av-48p575-48 in hdtv rear projection ?
Go to this page:
http://www.hdtvoice.com/voice/archive/index.php/t-16909.html
About halfway down are some good settings for picture, especially in theater mode on hd. As for the slant go here:
http://www.fixyourowntv.com/projection.php
Awesome site with good information. Go here for information on problems and symptoms.
http://www.fixyourowntv.com/symptoms.php
Good luck.
Posted on Feb 19, 2008
What can you do if the picture is black on top of screen, but most of the bottom looks good?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 08, 2017 | Samsung Televison & Video
Motherboard for SHARP TV Model LC42LE620L
you probably have it set on wrong aspect ratio, go to menu/picture set it to auto it will then chose the right aspect ratio of the prog being shown/transmitted, if you have other devices running through it, make sure they are set to 16.9 or it will never look right, it is a simple mistake, sometimes there is 1 prog that never looks right, you can then roll though the pic settings manually, tiil you get the best fill of the screen, 4.3-16.9 14.2 Cinema-subtitles-etc cinema would give u a full screen of 4.3 but cut a bit off top & bottom, nothing is perfect with all the different aspects but Auto wiil do its best.
Feb 23, 2015 | Sharp Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
We just bought the lc-32d59u and the picture is just not sharp at all it actually looks pretty crappy and I put the sharpness all the way upplease help im not sure if specific rgb gain numbers would help...
I was just reviewing the specifications on this particular model and I see that it is a 720P unit. If you already have HDTV's and they are 1080P units then you are definetly going to notice a difference. Also keep in mind if this is your first venture into HDTV older programming that is not in HD will not look good on an HD set. Try and find a HD channel and see how it looks if you havent tried this already.
Apr 11, 2011 | Televison & Video
Philips magnavox big screen tv that has sound but no picture
the picture driver has gone bad, look on ebay for one,make sure it looks just like the one you have, or it could be the verisitor has gone bad it's a kool fix
Nov 21, 2017 | Philips Televison & Video
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA P52920BL (1999)
The fuse fails when the convergence power supply fails,putting a new fuse in the set will let the unit come back on but convergence is not working,check in screens in the menu to see if you have adj. projection t.v.,if the is not in the menu,replace reg ic part number 215530 on the convergence power supply,this board is above the right module mounted on the black plastic.,hope this helps
Feb 28, 2008 | RCA P52920BL 52" Rear Projection...
Convergence
you need to replace the convergence ic'S inside the unit
Aug 17, 2007 | Sony KP-53S65 53" Rear Projection...
Phillips Big Screen Older Model
It means the fluid that cools each picture tube is low in the green but where did the fluid go,remove the back cover and check for a fluid leak towards the front side of the chassis and if any it should be right below one of the picture tubes.The description of your problem tell us you have a rear projection set but the heading shows a direct view tv.?????????? Since it was move the leak is only a possibility there could be other reason.Be careful and be sure set is unplug.
Sep 29, 2006 | Philips 32RF50S 32" TV
JVC AV-48P575 48" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
