Question about Toshiba Satellite M45-S265 Notebook
Wrong part of dan disk inserted in toshiba laptop
I put the wrong part in laptop the small part
  • 51 Answers
Then what happends?
Posted on Jan 17, 2008
HOW DO I CORRECT THE ERROR NO BOOTBLE DEVICE -- INSERT BOOT DISK AND PRESS ANY KEY ON TOSHIBA SATELLITE C875-S7303 WINDOW 8 LAPTOP?
Hopefully you have a boot disk that was created by you or the technicians who set up your computer. Put it in and follow prompts.
Jan 01, 2015 | Toshiba Satellite Computers & Internet
My Toshiba Satellite C665 Laptop will not start up, when I push the power button to turn it on it does not load or start. On the bottom of the screen it says press F2 go to Setup Utility or F12 to go to...
There is something wrong with your hard drive.. It is not being recognized by your bios. Could be a bad logic board. Get appropriate software and perform diagnostics on it to confirm
Sep 08, 2017 | Toshiba Satellite Laptop with Intel Core...
Upon putting dvd into player it will not load and screen says"no disc" please help!
Is this a problem with all disks or just some home recorded ones?
If all disks try inserting a cleaning disk (dvd or cd doesn't matter) or cleaning the lens with a small soft brush to remove dust.
If only home recorded ones it may be they are in the wrong format some players will only work with R- format disks others require R+ format.
Feb 25, 2011 | Toshiba SD-P71S Portable DVD Player with...
Hello I have a problem with my Toshiba Satellite L300D. When I start the laptop it shows just a black screen. I hear it working but the display shows nothing. Also it is really hot near the fan, but I can...
try to attach an external monitor and see if it works ..if it does it means that something is wrong with the screen ..either the ribbon or the back-light or something like that ..
do not forget to activate the external monitor with Fn +F4
if it do not work with external monitor either ..than probably its the ram memory or the video card ..I wil open the back where the ram memory is ..and remove them and put them back ..If you have more than on e..just insert one at the time cause one might be damaged ..
also try to insert a operation system disk ..and see if it boots from the disk ..in this case you just messed with the video card settings ..but I doubt cause it should show at least some writing before going blind.. but if it do not show anything its usually from the display ..(in this case will work with an external one ..)
Sep 29, 2010 | Toshiba Satellite Pro L300 Notebook
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
My laptop ate my disk
The CD drive is secured by a small small screw which is located on the under side of the laptop, it normally has a small picture od a cd next to it, if you remove the screw you can slide out the CD drive.
once you have remover the CD drive you can undo the small screws on either side of the CD drive and open the drive and remove the cd, reverse the steps to put it back in the laptop.
However please take care and be gentle
hope this helps
Dec 21, 2009 | Toshiba Computers & Internet
Trying to use Toshiba "recovery Disk creator"
u need a blank dvd, or tell the program your using regular cd, it will be like four dvd's or like 11 regular disks. in some cases it wont work with either, i have seen it where the program just doesnt know any disk is inserted or blank. if thats the case, update the program or contact toshiba
Sep 01, 2009 | Toshiba Satellite L305-S5907 Laptop
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba laptop will not start up, have tried inserting start up disk, nothing happens
On the left side of the laptop, there should be a small hole that like a pinhead. Insert something small enough to fit but sturdy enough to not break.This should reset oyur laptop. If this does not work,you have to call Toshiba's support line and send thelaptop to them. There is a nominal standard rate for the service of resetting the laptop. but it is not that expensive. When you get your laptop back it should work or Toshiba will tell you exactly what your problem is.
Jul 15, 2008 | Toshiba Computers & Internet
Toshiba Satellite pro hl-dt-st dvdram gma-4082n
goto program defaults/media player/disc insertion= and choose the options you require. Or goto computer-cd/dvd drive and choose the program you wish to run the disc
Dec 10, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
