Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
My Mac wont work. blinking Folder with "?"
I start the comp, the apple appears and it dings and then all of the sudden it blinks a folder with a "?" on it and it has a buster symbol around it.
how dod I fix this? what is it?
  • 26 Answers
Another alternative is to hold the "option" key as the Mac boots up to force it to recheck possible blessed start-up disks. If your hard disk drive shows up, select it. When it boots into OS X, immediately back up your data and restart the Mac with the OS X DVD (or CD) Install Disk. When you're in the boot menu from the OS X Install Disk, select "Utilities" then "Repair drive" and select your HDD. That should help OS X repair any file permissions or data corruption that may have occurred. I would also look into getting a new HDD. It seems to me that your current one may be failing and need replacement.
Posted on Jan 18, 2008
  • 667 Answers
That is never good since the Mac cannot find a usable operating system folder. You will need to start the computer from a system CD/DVD and repair your harddrive with disk tools.
Posted on Jan 17, 2008
My macbook air start to show me a white screen white a blinking folder inside
Sound like you have an issue with either your hard drive or the operating system has lost the plot. Try this OS About OS Recovery
If you are able to access the recovery partition then use the disk utility to check the disk.
If this does not work then take the computer to an Apple repair centre, if it's still covered by warranty the disk might be replaced under warranty.
If it's not covered, you could try using DiskWarrior 4 The Disk Utility for Mac Disk Repair Mac Directory Repair... which has allowed me to recover disks that have not been able to be repaired with Apple's disk utility.
Dec 28, 2013 | Apple MacBook Air
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
My screen is on but just have a small camera in the middle of the screen blinking.. G4 power book can you help?
I seen a blinking folder with a question mark in the middle in folder, in the middle of a display screen, but not a camera.
Either way, you are not able to access your main desktop so that is where I want to help.
A blinking folder with a ? in middle, is an indication that your bootable Mac OS X volume cannot be found.
If you do, I would first recommend you try this procedure first:
(PRAM Reset)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} • First, hold in your power button for approximately 10 seconds to do a hard shutdown, if you have not already turned your Mac off.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the computer.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Powerbook G4 to start up.
If this still returns you to a blinking ? folder, try this process:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} DISK UTILITYYou can use your Mac OS X install disc to repair your hard drive and Mac OS X volume using Disk Utility. Click the link below to try this procedure.
* Apple Support Link:
Use Disk Utility to Repair Disk
Should neither of these processes work and you still boot up to a flashing ? folder, then your only recourse is to use your Mac OS X installation disc and perform an Archive and Install procedure.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files and creating a new Mac OS X Directory.
Here is the Apple Support Link for that procedure:
Archive and Install
This should get your Powerbook G4 back to normally functionality without any serious data loss.
Regards,
-Mactechtrainer
Feb 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
My problem regarding Mac Book white-screen w/ blinking ?-folder has already been answered by kklare. Sounds good to me, but he didn't address whether your files (etc.) would be erased by reinstalling the...
Normally if you reinstall the Mac the files wont be erased and you are just repairing it.
If you dont find the HDD option while reinstallation, it would mean that the Hard Disk is Crashed.
Here is the Answer to the Problem - A flashing question mark appears when you start your Mac by Apple
http://support.apple.com/kb/TS1440?viewlocale=en_US
Hope it helps you!
Sep 13, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Blinking file folder with question mark and a DVD is stuck in it
Hello, The blinking file folder with the question mark can happen when the computer doesn't "see" your System. It can be caused by a faulty hard drive, or by a damaged operating system. You can try to reboot the mac, hold the mouse button during 20 seconds to eject the CD, then insert you installation DVD (leopard). Reboot the Mac again, and hold the "C" key. Select english, the go to the tools menu, and Disk Utility. Go to the SOS tab, select your drive and click "repair". If something red appears, it means that it has found something wrong on your hard drive. Best regards
Jun 10, 2009 | Apple MacBook Mac Notebook
When the "?" mark comes up, it means it's looking for the operating system to boot to. It can be fixed by opening system preferences and in the startup settings, select your operating system as the tarted startup. It should speed up boot up time.
Apr 06, 2008 | Apple Power Mac G5 Desktop
Blank screen
It's a hardware failure. Try reinstalling the OS, otherwise it sounds like apple gave you a LEMON. LOL (little humor there). This also happens when there is no OS installed at all, which doing the above may solve the problem. Also, check to make sure the Hard drive is formatted for FAT~~ and not NTFS, cause for some reason, apple system hate NTFS Drives.
Jan 26, 2008 | Apple MacBook PC Notebook
My mac wont work. Blinking folder with a ?
sounds like like your hardrive has died or you have lost your operating system use the recovery disc that came with your computer to reload the computer as it was from the factory.
IF this doesnt work replace your harddrive
Jan 17, 2008 | Apple MacBook PC Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
2,053 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
