Question about Palm Treo 755p Smartphone
Phone OFF I cannot get my phone out of "Phone Off" mode. When I press the green talk button - It tells me phone is off and offers to turn it on. When is press "yes" it does not change. I tried soft and hard resets. This began when my phone started flashing Palm/Access.
  • 2 more comments
  • Vince10 Feb 11, 2008
    I have the same problem, and can even get the phone powering-up screen and noises, but after that finishes, the phone is still off. This first started after I charged my phone after the battery went dead. The top left-hand corner of the phone has said "searching for network" ever since
  • sascaesar Feb 24, 2008
    I am experiencing the exact problem, it is so frustrating!!! I have tried holding the power (red) button for as long as 10mins and still nothing. I loved my phone at first, now I'm not so sure...
  • Anonymous Mar 24, 2008
    mine goes to Network search & couldn't turn ON the phone did hard rteset several times. took phone with sprint & they couldn't fix it
  • Innominate May 22, 2008
    Same problem ... happened after a Warm Reset to fix the Access Powered/Palm OS startup screen cycle (wouldn't boot)
It happened to me as well. I removed the battery for a couple of minutes. Don't touch any of the keys till it fully reboots itself. then hit voicemail button. it will ask you if you qould like to turn on phone click on yes again dont touch any keys it will turn on and you will see the verizon logo screen it will begin to search network and put you into your voicemail click end call and if you are as lucky as I was your phone will be on. Good luck Rich
Posted on May 28, 2008
Tried it still doesn't work.(device is on but phone is in network search mode) took it to the sprint technical support & even they couldn't fix it.
Posted on Mar 24, 2008
  • 23 Answers
Try and holding the end/red power button, and post and let me know if it works or not
Posted on Feb 12, 2008
When i get a phone call i don't know how to answer the call,what do i press to talk with the other person,as you can tell i'm new to this,on a new STK mobile phone
There prolly is a red and green button. Press the green button to talk. Red to hang up.
What model and make is your phone?
Sep 07, 2017 | Answer Lands Phones
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do I turn the ringer on
It depends on the model and why the ringer is off. All of these solutions require the phone to be in standby mode. If your phone has the Uniden Do Not Disturb feature enabled, you need to press the DND button on the base. If your Uniden phone has a Silent Mode, press and hold the # key (below 9) on one of the handsets. You'll need to hold the key for ~5 seconds. These options will toggle on the feature when it is off.
If the ringer is merely muted, press the volume up key.
I hope this helps. If you post a comment with the model of your phone, I can tell which feature is offered for that phone.
Jun 07, 2015 | Uniden DECT 6.0 Cordless Phone
How to reset a Nokia Express Music Phone?
If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button--default code is 12345.
For HARD Reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up
Dec 20, 2011 | Nokia Cell Phones
My phone is getting hang i want to format it software
go phone setttings and find restore categorise
Feb 23, 2011 | Nokia 3230
How can i fully formated my nokia 5800 express music
The reset will restore all the phone’s settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
For hard reset
Switch off the phone and Press GREEN + RED + CAMERA + ON simultaneously until you see the “Select country
May 20, 2010 | Nokia 5800 XpressMusic Smartphone
When i turn on my phone the push to talk come out n my phone cannot work..what it prblme?
press the power button to get the shutdown options. take flight mode or offline mode then press ok now change the profile to general press ok now in settings > push to talkor PTT turn off enquiry
Jul 04, 2009 | Nokia 6300 Cellular Phone
How do I turn off the speakerphone on my rumor 2?
You have probably noticed that you can place or answer calls by pressing either the green "TALK" button or the "speaker" icon right above the green "TALK" button.
When you press the icon, the phone is in speaker mode. When you press the "TALK" button, the phone is in earpiece mode. Be careful about which button you press.
Jun 29, 2009 | LG RUMOR Cellular Phone
Code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
SP unlock *#0003*(secret code 8 digits)#
*#0606# shows you Secret Code, but only without SIM Card.
*#06# for checking the IMEI (International Mobile Equipment Identity)
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) >abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
Resets language to automatic selection : * # 0000 # then Green button
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
Tone Pulse
yea.. this happeneded to me aswell.. here's what you do: (this is in the manual btw) TONE/PULSE SETTING 1. Make sure the phone is OFF (not in TALK mode). 2. Press the program button. 3. Press * tone button for tone or # pause for pulse selection. 4. Press the program button again. You will hear a confirmation tone.
Feb 28, 2007 | GE 27990GE3 Cordless Phone
Palm Treo 755p Smartphone Logo
172 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
