Question about Olevia LT26HVX 26 in. LCD Television
Do you still have this Olevia 26 LT26HVE LCD TV? I am looking for a power supply for mine. If you are will ing to sell it let me know.
Posted on Sep 29, 2008
  • 86 Answers
Hello.there is companys that do repair lcd screens but the cost is enormus.i have enquired about these as i do repair lcd & plasmas. it would not be economical to repair .
Posted on Jun 05, 2008
  • 102 Answers
I'm sure it can be. Just ask the manufacturer/shop how you can get it replaced. If you can prove the crack happened because of a fault on their part they should replace it for free otherwise be prepared to pay a decent amount of money.
p.s. You don't have to shout.
Posted on Jan 17, 2008
Is my Android tablet LCD screen cracked as well as the digital screen?
and you just learned a 45 dollar lesson . they are not made to sit on .
Aug 06, 2015 | Xelio P1001A-BK 10.1" 4 GB Black Tablet...
I have a kenmore coldspot model 106.53532300 and the water will not dispense from the door the icemaker is working just can't get water from the door...really miss it! Can anyone tell me what to do?!...
Hello Ray;
My name is Peter. I am a retired field service refrigeration technician.
Ok, It may have been the water bottle. But, you have an old unit.
So, lets check it out once more.
1.) After time, from the heat, the plastic tubing for both your water lines to the water dispenser and ice maker will dry rot and crack.
Check: Pull your unit out. Have someone draw a glass of water from the water dispenser, while observing in the back both the water supply valve and the larger plastic tubing going to the water dispenser. Is there a leak when pressurized?
2.) Wait for when your ice maker fills and observe the smaller plastic tubing. Does it leak under pressure.
kenmore-coldspot-model-106-53532300-q5zw2lslmquh13tixvlr3ryr-3-0.jpg Part Number: Substitution: 4387492 Cost: $10.00
3.) Drain Pan - This too will crack over time do to heat. Pull your unit out so you can get behind it. Remove the lower back cover.. There are about 8 screws easily removed. Observe the drain tube from the under body of your refrigerator and the black drain pan where it empties. Observe around the drain pan. Are there and brown or dark stains on the floor? If so, then you have a cracked drain pan.
Repair: Unplug the refrigerator. The compressor and surrounding copper tubing prevent you from replacing the pan. When I was in the field, I would take duct tape and seal the cracked area. Then, I would cover the duct tape and surrounding area with a high temp silicone adhesive.
Mar 19, 2015 | Kenmore Refrigerators
Hp slate plus 4200ca plus broken screen wont power up
Probably a crack on the motherboard but if you are lucky, maybe a broken switch. Strip it down to find out.
Mar 11, 2014 | HP Computers & Internet
When i turned my camera on I got a large image of a crack expanding from the lower right hand corner of the screen. Most of the screen is black and the cracks are lit up white. There is a blue patch of...
Sounds like a cracked screen. My Rebel t1i looked the same way when i dropped it a month ago. Not sure of cost to repair i never looked into it but probably not cheap.
Apr 08, 2011 | Canon PowerShot G9 Digital Camera
Cracked screen on lg lcd tv small crack 6in up an 8in from right can still see picture ok but have a 1in white line running down from small impact area and a light grey 1in line across from impact area...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 22, 2017 | LG 32LD450 32 In. LCD HDTV
Lg phone screen cracked but when you look it closely it doesn't have crack lines. crack lines only appears when it is turned on and not present when the phone is turned off why am i suppose to do?
The glass of the lcd screen is not cracked, but internally the display is'nt working perfect, few lines are not displayed on the screen which makes us to assume that the screen is cracked which is not the case, you need to replace the display, it its one or two lines you can use the same display screen, their won't be any damage to your phone due to non display of few lines.
Jul 29, 2010 | LG Televison & Video
Screen is blank/ w. small horizontal lines going across it
It sounds as though you may have cracked you screen or damaged the LCD cable. This can be hard to tell because many new phones have an outer screen that does not crack when the inner one does.
Feb 04, 2010 | LG Neon GT365 Cell Phone
Screen has an "LCD" leak apparently.
The LCD is not cracked, however either the ribbon cable attaching it to the mainboard or the mainboard itself is cracked or the phone has a bad processor.
If the phone is under warranty, get it replaced.
If it is not, you may be able to open it (depending on what kind of tools you have).
Check all cables and boards for damage, seat all connectors firmly, and re-assemble.
If it is a smart phone, you can get replacement parts if needed.  If it is not, your parts options are limited.
Dec 15, 2008 | Nokia 5300 Grey Cellular Phone
Open Questions:
Olevia LT26HVX 26 in. LCD Television Logo
125 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
