Question about Samsung SyncMaster 940N Flat panel Monitor
Monitor flickering and adjustment buttons locked
The monitor is constantly flickering. Occasionally the screen just turns itself off. the desktop is off centred and the auto adjust button works until you hit any key. then an error screen pops up and says auto adjust locked. please help this is very annoying
  • 383 Answers
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Posted on Jan 17, 2008
Baki
Posted on Feb 05, 2009
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
Computer monitor cycles on and off when the computer boots up but seems to have constant power when just turned on
The boot process goes through various display modes. Each time it switches, the monitor has to set itself for that mode. This causes the monitor to flicker while it's adjusting. Perfectly normal operation.
Sep 02, 2014 | Acer Computers & Internet
How to fix Syncmaster 2494hs touch menu problem?
Have you tried doing a factory reset on the monitor? If the problem persists, then it could be an electronics fault or a stuck button.
May 11, 2014 | Samsung Computers & Internet
Occasional odd coloring and backlight flickering
Please check it monitor color adjust button. If ok then you check it monitor cable if change possible then change it or power cable also proper connect. If not solved contact Good Monitor technician.
Thanks.
Feb 17, 2014 | Apple Cinema Display 23" HD Monitor
Auto adjustment locked and picture is fliker
Its not auto adjusting because of the flickering. Its flickering because the screen itself is losing voltage so it cant stay on. You can try hooking up the monitor to another computer just to rule out a bad video card but it looks like replacing the LCD is the only solution.
May 25, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
Aug 31, 2009 | Gateway SX2800-01 PC Desktop
MONITORS TURNS BLANK OCCASIONALLY AND THEN COMES SPONTANEOUSLY BACK TO NORMAL. ONCE THE IMAGES STARTED FLICKERING. I HAVE THE IIMPRESSION THAT THE MONITOR NEEDS TO "REST".. THE TURNING BLANK HAPPENS...
it seems to be the power management
right clik on desktop click properties
click on screen saver tab
and from there click on power
ther you can adjust monitor stanby mode
Jul 24, 2009 | Computers & Internet
My monitor is showing constant 'auto adjustment in progress' in every 3 sec, i cannot get rid of it.i cannot watch any movie or read my email.constant getting black out and showing me that same msg
it happens because you have selected( accidentally or otherwise) the resolution that the monitor cannot handle easily. So each time turn on the computer the screen tries to adjust itself to work with the resolution that you have selected. Select a screen resolution that the monitor can handle and work with.
May 17, 2008 | HP Computers & Internet
Northgate Monitor - Model No. KM-718
Hi, Assuming that the monitor does not have any problem or defective components/settings, you can try adjusting your PC by: 1. Right click on any clear are of your desktop; 2. Click on properties; 3. Go to Settings tab; 4. Set your Screen Resolution to your desired size; 5. Verify that you have Highest (32bit) setting in your Color Quality; 6. Click on Advanced button; 7. Click on Monitor tab; 8. Select highest Screen refresh rate (maybe 85 Hertz) within capacity of your video card & monitor; 9. if a selection or setting does not work, pressing escape will revert you back to the previous setting; 10. Apply, OK. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Oct 01, 2007 | Computers & Internet
Samsung SyncMaster 940N Flat panel Monitor Logo
913 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
