Question about Toshiba Satellite M40-S417TD Notebook
LAPTOP /no power
Hi Guys,
This notebook has not even a power led , is it possible to check input voltage ,with adaptor connected ,at the terminal that connects to the motherboard ,with a multi meter ?. If i know the power is getting that far then i i can check another on / off switch after that i guess there is only the motherboard that can be faulty. It is completely stripped at the moment, apart from memory / cpu and cooler still on motherboard.
Thanks
Penost
  • 3 more comments
  • Anonymous Mar 21, 2008
    Toshiba laptop fils to power up when power button is depressed. Was in fine working condition the night before when used. No explanation.
  • Anonymous Jul 12, 2008
    Toshiba Satellite computer in great condition the night before fails to power on when power button is pressed. Computer is receiving a charge as battery has been removed and lights are on when plugged in.
  • ice vampire Sep 08, 2008
    I have a sony vaios pcg-672r Notebook the ac jack works battery but there is no power at all?
  • nargre Feb 04, 2009
    no power. the laptop just lost power and will not come back on
  • chuckbombay Apr 21, 2009
    My toshiba satellite A-75 had a bad motherboard connection that was covered by a recall. It happened again. If I have to pay for motherboard this time,I'm going to buy a new laptop that won't be a Toshiba
  • 383 Answers
It states you are not getting no power on your lap top computer :
No power or computer does not turn on Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Note: If the computer is turning on but is not posting (beeping) or giving any type of picture on the display, please see document CH000607. If you are uncertain if the computer is turning on or not, this can be easily checked by locating any fans in the computer or visible from the outside of the computer. If these fans are spinning, the computer is receiving power and this document may not apply to your issue. Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Good Luck,Please dont for get to Vote,Thank You
Posted on Jan 17, 2008
6ya staff
SOURCE:
The battery is not recharging
Possible that the battery is bad or weak, the adaptor is not outputing the required voltage or is faulty or that the charging circuit is faulty in the motherboard.
In all these you need to check on the voltage incident on the battery terminals. So connect the adaptor an check the voltage at the battery terminals in the laptop, if absent check at the pins, if absent check on the adaptor circuit.
check this link;
http://www.fixya.com/support/r5164850-laptop_power_supply
If voltage is present then the battery is a suspect, if not the motherboard charging circuit has problems if adaptor is good and there is no charging.
Sep 17, 2011 | Acer Aspire 3623WXCi Notebook
I HAVE AN INGERSOLL RAND SSR HP/40SE AIR COMPRESSOR W/INTELLISYS CONTROLLER 15-50 HP.IT HAS POWER,BUT DOES NOT HAVE ANY LED ON SCREEN.CHECKED CONTROL VOLTAGE-OK POWER LT ON,WHEN PUSH BUTTONS NOTHING...
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Mar 27, 2011 | Ingersoll Rand Stationary Air Cooled...
My Sony Vaio VGN-NR21J Lost power, the DC jack and charger were replaced but still no power to the laptop. What woudl be my options from here? Is there anything else that could be causing the power loss?...
In the first place before the adapter was replaced you should have checked the power to the battery and the battery terminals. Now if there was no power from the adapter/adaptor pins then it is also possible that the wire is hort within and so the SMPS cuts off .
Since the charger was replaced then the voltage at the battery terminals must be checked to see if the power comes into the laptop for charging. If the laptop does not power ON even with a battery in full charge , then it is possible that mother board is faulty and a cost estimate is important before the board can be changed.-- compare with the cost of a new laptop.
Jan 17, 2011 | Computers & Internet
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
No power from ac adaptor
No, there are no reset button or fuse in these laptop adapters, they are a sealed unit. The lead/plug maybe broken at the plug. Test the voltage at the plug with a multi-meter, the output voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Oct 21, 2009 | Toshiba Satellite Pro L300 Notebook
HP Pavillion dv6000 -when I plug in AC adaptor, it won't charge
Hi ja525,
If you have tested the power adaptor with a multi-meter to confirm it is OK or the other adaptor is also OK assuming that it is the correct voltage and at least the same current rating. Then the fault is most likely the power connector in the laptop.
To confirm this, power up as normal with the power adaptor connected and switched on, when the blue LED dims wriggle the power connector where it connects into the laptop and if the LED comes on or blinks, that means that you have a faulty power connector, it couls be a dry solder joint at the power connector.
It is possible that the power adaptor is shutting down (thermal overload) due to insufficient current capacity, Check the Amp rating of the laptop, it is usually on the lable on the botom of the laptop and check it against the power adaptor, the adaptor should be equal too or greater that the laptop's current rating.
To fix a faulty connector, you can dismantle the laptop and with a fine tip temperature controlled soldering iron, resolder the power connector and hopefully this will fix your prolem.
Nov 18, 2008 | HP Pavilion dv6000z Notebook
Technical information
If the adapter is working, the problem could be the jack on the back of the notebook. The nice thing is most of the Vaio notebooks the jack is replaceable without having to solder the jack to the board. I would call SONY regarding the jack for a mode number and a picture. it's easily replaceable but requires the disassembly of the notebook.
Jul 22, 2008 | Sony VAIO PCG-K35 Notebook
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Toshiba Satellite M40-S417TD Notebook Logo
4,503 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
