-   when i plug the power cord in smps it starts and then stops.no id cable is inserted in motherboard. light turned in the mother board but cpu fan stops . -   Guest
Feb 06, 2008
-   i am trying to boot from internal CD rom drive but the system didn't start up.. i tried usind an external cd rw drive. it reads the windows xp installer however after 10 seconds of start up.. the screen turns to blank.. what is the matter in here? my board is P5V800-MX-   grace_0811
Sometimes motherboards turn the system off when it thinks that the CPU fan is faulty or missing - so try this ...
1 - check that the cpu fan power cable is connected to the 'cpu fan' connector on the motherboard, not the system fan connector.
2 - remove the cpu fan power cable and then re-connect it in case it had a bad contact. Sometimes, excessive dust on the terminals can cause a problem so make sure the connector looks pretty clean.
