Question about ASUS P5PE-VM Motherboard
System starting problem
When the power is turned on, system starts momentarily and stops working within 3-4 sec. but the LEd on the mother board remains on
Replace your motherboard because the power circuit in your motherboard have no supply of power or damage. When you try to repair or probably replace those circuit which is damage in your board is not 100% ok... It is 30% to restore and 70% which is not ok... Hop you know what i mean. Motherboard is a very sensitive to replace their circuit even the capacitor... Anyway, hop my solution can help! By the i finish electronics and computer technology.
Posted on Sep 18, 2008
    Novelist:
  • 198 Answers
The led on the motherboard is a voltage indicator on the +5v power wires from the atx power cable (the large group of wires that enter in your motherboard). Even if the power source is broken and can't supply larger 12V tensions, or other smaller values that +5V tension will be most likely still present. The fact that the led is on doesn't tell us much. You should try to check the power source. Try replacing it at least just for some testing. Normaly this should solve the problem. However if this doesn't work please provide a reply and we will try other solutions.
Good luck.
Posted on Jan 17, 2008
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
I have an Intel E210882 mother board. Within a week, it was starting to become hard to boot, then I had to boot in F8 mode, and now when I turn on the power switch, the LEDs light turn on and the cpu fan...
If you have another computer that will hook up to the internet, download a copy of any live Linux CD (UBUNTU) and see if the computer will boot with that (you download a image file that burns to a boot able cd). If it will boot with a live CD, then you have a Hard drive / operating system problem. If it will not boot from that, you have a mother board problem. Start removing things from the motherboard, unplug and remove everything then plug hook up things one at a time.
Sep 18, 2010 | Intel Motherboard
When I connect 2nd and 3rd hard disk my system wont starts......
Just because it has a CPU, it is not a brain
It is ok to set up 2 or 3 harddrives BUT... make sure one is a master, (C:)the others are slaves D-Z
Look at all drives, most now have jumpers and they are master,slave,cselect.
To make it easy, slaves/masters
Jul 24, 2010 | Intel D915GAV Motherboard
When i turn my comp on the lights and fans start for about 1 or 2 secs then stops my make of comp is zoostorm
Pleease remove all connections (including Front Panel pin assignments) from Mother Board except Power Supply.
Now find out reset pin assignment on mother board and shot that pin if its woking then again do all connection and try.
other wise dismental complete system and re-assemble sytem. your problem will be solved
Mar 20, 2010 | Computers & Internet
Mother board 845 LDA as i switch on LED Blinks & Processor Fan Momentarily Starts then it gets off
I have built quite a few PCs and I have often found the same problem when trying to boot for the first time. An old trick that might help is to repeatedly energize then drain the PC electricity.
Do this by plugging in the PC momentarily then unplugging it then immediately pressing the power button on the PC while there is no power hooked up. Do this several times over and over again in quick succession. Finally turning on the PC with the power connected. If the power supply on the PC has a switch on it you may use that instead of actually plugging and unplugging.
Also you might try pressing and holding down the "ins" or "insert" key while powering on the PC.
Hope this helps.
Apr 25, 2009 | Intel Motherboard
Power drops aprox 1 minute after start
Good day!
It's the power supply, usually the fan of power supply run once it start normally, Replace the power supply. And try to turn on the unit.
Feel also some part of the mother board if they are hot like the heat sink the power supply casing do it when the power is off.
Thanks.
Nov 06, 2008 | Foxconn (945G7MA-8KS2) Motherboard
My washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the "ON" led just light up 3-5 sec then turn off
my washer Maytag Neptune Model MAH3000AWW not working. After push the START button, the led just light up 3-5 sec then turn off
Aug 21, 2008 | Maytag Neptune Washer
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
New mother board
sounds like either you have button connections wrong or you need to set bios defaults
Nov 12, 2007 | MSI PM8M-V Motherboard
ASUS P5PE-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
