Question about Maytag Neptune MDG5500AW Gas Dryer
May tag neptune says pf and i can't get it to run
    President:
  • 1,891 Answers
PF CODE STATES ( power has been out) unplug it and try again . it will still say p f but it should program .. if not is't a bad control and will need replacing .. mm
Posted on Dec 04, 2009
SOURCE:
MY maytag neptune dryer center wont start when I press the start button on the bottom unit it shows PF
The PF is a power failure code and it indicates the control is not sensing any line voltage
Check the circuit breaker for the dryer is not tripped. The PF could be caused by a voltage drop during a storm but you should be able to clear it and run the dryer
Oct 14, 2016 | Maytag Dryers
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
How do you fix the maytag neptune pf code for the dryer??
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Codefor Appliances
heatman101
Apr 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What does pf mean on the controls?
The code PF indicates that a power failure occurred while the dryer was running. Press pause/cancel to clear the display. Hope this helped and best wishes.
Aug 12, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Won't run, shows code PF
Well the code pf means power failure, check your cord and see if it connected ok. make sure you didn't blow a breaker in your powerbox.
Apr 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer PF Error Code
PF is a 'Power Failure' code meaning the dryer power may be interrupted. The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle). If all looks OK, Check the power connections at the dryer. If looks OK the electronic control may be defective.
May 31, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
276 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
