Question about Lightning Audio S2.300 2CH 340W Amplifier Car Audio Amplifier
Connector While I was half way across the country my little brother thought it would be a good idea to hook my S2.300 up in his P.O.S., anyways he got pulled over no license so he unplugged my amp & Let the bass boost chord & connector plug get impounded with his car, so my question is where Can I get them replaced???
  • 107 Answers
Ebay..? dont know if they have.
Posted on Jan 18, 2008
6ya staff
SOURCE:
How do I replace the bobbin hook after cleaning my Brother XL-3030?
you may be able to enlarge the manual page:
Brother XL 3030 User Manual Page 60
The hook (half-moon piece) needs to go in first, but you may need to wiggle it to seat it and then hold it while you fasten the outer retaining ring (hook race). Flip the levers up to hold the ring in place. Then install the bobbin case.
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
FWIW, my machine oiling instructions say to apply a drop of good quality oil on the outer edge of the hook race lip where the hook rubs as it turns. But, your manual should explain where to oil.
Dec 22, 2016 | Brother XL-3030 Electronic Sewing Machine
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
I am looking for the part that goes INSIDE where the needles are held on my Brother 1034D. I overtightened my needle holder and snapped it in half. The repair man told me to find it online myself, but he...
Call Brother at 1-877-276-8437 and order right from them. They will know exactly what you need and you can be sure that you will have the right part. Their site is brother-usa.com and it is real good for getting information and a copy of your manual for free. The download of you manual will let you enlarge the diagrams (nice to have a backup copy anyway) and possibly see how to replace your part yourself, but ask them when you order if you can do it yourself without special tools. Good luck
Sep 17, 2010 | Brother Lay-In Thread Serger Mechanical...
Failed illinois emission test for no communication. Car will communicate with our snap-on solus pro. Any ideas?
Well first check for power to obd2 connector, the next thing i've seen alot off is a worn connector some of these testing places have worn hook up connectors tell them to try to hold plug in place with a little force but also make sure all the fuses are good , If your scan tool works then theres should also,
Jul 04, 2010 | 2002 Daewoo Nubira
Right half os the screen is blank on my T!-84 Plus
Have you activated the split screen feature? That could explain the apparent defect. Anyway, to know how much it would cost you to replace the screen you should contact Texas Instruments at [email protected] They should be able to advise you, given your country of residence.
Feb 28, 2010 | Texas Instruments TI-84 Plus Calculator
Vertical lines half way across screen.
Try performing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
The bobbin thread does not fully rotate in the bottom in order to catch the top thread. The bobbin thread stops halfway... looks like the hook is not catching the thread properly. How do I fix that?? (This...
Is there thread caught in the bobbin case? How far are you turning the wheel and are you holding the end of your bobbin thread out so that the top thread can hook it?
Nov 22, 2009 | Brother Sewing Machines
More Laptop issues
Most likely video memory.
Try to hook up an external monitor and switch from your LCD screen to the external (Fn key and F7 or whatever key indicates by a little picture that you can go to another monitor.)
Does that work? If so, your video on the motherboard or video card is bad.
May 07, 2009 | IBM ThinkPad R40 2722 Notebook
How To Collapse The Stroller
Lift up on the little grey plastic knob like structures on the sides of each arm. The stroller folds foward then fold in and hook the little grey latch in the middle inside of the stroller.
Good luck.
May 05, 2009 | Baby Gear
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Lightning Audio S2.300 2CH 340W Amplifier Car Audio Amplifier Logo
61 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Mark Skinner
Sheldon Dedek
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
