Question about Freezers
Upright Freezer Freezer belongs to a friend in another city. I looked at it a few weeks ago and replaced the 9 volt battery that keeps the memory ( I guess that is it's purpose ). The battery only lasts a week and the red trouble light on the door comes on. No error codes appear on the key pad and the freezer maintains setpoint. What could be draining the battery? Thanks.
  • 417 Answers
Check that the back light is not on all the time as this can.
Thanks J
Posted on Feb 16, 2008
My frigidaire upright freezer has been working fine until about 2 weeks ago. Now pizzas aren't freezing and freezer corn is soft and i put a ham in it and that was a week ago and it is not froze.
There should be a temperature adjustment inside the freezer somewhere. It will look like a slider or a dial, and be labeled something like "Colder" and "Less Cold" on opposite ends of the scale. If this is set to its coldest setting, and the temperature still is not cold enough to solidly freeze food (ideally, a freezer's temperature should reach ZERO degrees Fahrenheit), then the unit needs to be serviced by an appliance repairman.
Nov 30, 2017 | Frigidaire Freezers
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
My kenmore upright freezer won't stop beeping and everything is still frozen ???
hey.. look for a 9 volt battery. its for the memory and power failures .. so it needs to be replaced ..
Oct 19, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Where is the 9-volt battery located?
Welcome to FixYa.
The 9vdc battery should be just below the door on the right hand side, ( from facing the front ) some models have it behind the toe panel/grill in said location...lower r/h.
That should answer your question. Thanks for choosing FixYa.
Please take a moment to rate the info provided here today.
regards,
macamrkus :)
Aug 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Where do I install a 9 volt battery?
much better to call technician to install that if you confusing to install then observe it next time you can do it on your self
Mar 18, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore freezer depleting 9 volt batteries, setting off alarm
trojo50,
your defrost elements are not working or the water inlet for the evaporator tray is clogged. That alarm is to let you know something else has triggered it. This could be s imple DYI solution or require a service call. let me know if you are up for the DYI.
randy320sgi
Feb 11, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Upright Freezer 253.21741104 Loss of Power
Yes, it does have a control board. It is located under the rear of the freezer near the compressor. There was a service bulletin out a few years ago about the exact problem you are having. I will not be able to find out if your freezer falls under this design change until tomorrow when I get on my computer at the shop.
What is happening is the board has a fault in it that won't allow it to come back on sometimes if the power blinks off and back on. I am not sure if the repair credit is still active but we have changed the control boards on many of these units free of charge as recently as a year ago.
I will reply back when I find out for sure.
Oct 28, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Freezer Alarm
You can take the batteries out that power the alarm system. They are located through a small access panel/door front bottom right of the unit. If you bought the unit at Sears, you should call 1-800-4MYHOME and ask a technician if a replacement manual is available, or if they can direct you to a website for it.
Jun 09, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
130 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
