Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Browse popular Problems
Most Common Problems for:
Whining during spin cycle
zato2 on Jan 17, 2008
I've got an 8-yr old MAH4000. It's still operating just fine but recently it has started to make a loud whining sound during the spin cycle. It sounds a bit like a jet engine. What might this be and am I headed for trouble?
Comments:
Jan 19, 2008
- Thx. WIll call maytag repair.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Nov 01, 2008
-   mAKE NOISE DURING SPIN CYCLE-   Guest
Best Solution
posted on Jan 17, 2008
Helpful)
handiman518
Rank: Master
Rating: 79%, 13 votes
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Was this helpful?
Yes
No
Related Problems
Have a Maytag Neptune front loader washer and the door won't...
maytag top load mtw6600tqo fills for a bit then flashes F...
it fills, agitates and pumps water out just fine. Originally...
I've done an exhaustive search of your data base and haven't...
I have a Maytag front loading washing machine (model number...
Can you Help with these Washing Machine problems?
Maytag Neptune MAH4000AWW door...
Solve
The door lock light does not come on. The drum turns but does not spin out the water after washing.
maytag mah2400a washer, starts to...
Solve
This is a maytag mah2400a frontloading washer that is 4 years old. It stops through the middle of... (More)
Same problem with mine
Solve
Everything works great, except the water never goes into the fabric softner. I have to manually put... (More)
Maytag Neptune MAH6500 drum filled w...
Solve
My Maytag Neptune MAH6500 leaves clothes smelling moldy, the round drum when spun after clothes are... (More)
Maytage Neptune E3 code - Model...
Solve
Maytage Neptune - MAH8700AWW same problem as PMLAPL - Code E3 and machine won't finish cycle.
Sponsored Links
Describe your Washer problem:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 2541
Experience: Have knowledge with just about anything that is electrical, mechanical, or electronical & more!
Ask Me
Find more Washing Machine Experts
Top Washers & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 347-7500
Appliance Specialist We Sell New &...
Charland Appliance Service & Repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
