Modem has no power, will not turn on @ all,gateway bought june 07 what could the problem be? already tried replacing the power cord but still nothing.
  • Anonymous Sep 23, 2008
    The on-off switch on my Siemens Speedstream modem keeps turning itself off, every few hours.
    Genius:
  • 1,665 Answers
Perhaps power On-Off switch is faulty.
what is model no ?
Posted on Jan 17, 2008
Worth repairing?
if you are not afraid to open the set, I would suggest checking the power supply capacitors!!!!!! If you are not willing to do the work yourself, it will be cheaper for you to buy a new set vs. taking it to a TV repair man. Do you have any tech savy friend?
Feb 17, 2014 | Samsung LN40A330J LCD TV
Red power light, green wireless light, no internet access. Have done the reset and the power off. Nothing works.
I had the same problem on the Gateway 2701HG-B supplied from ATT. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at abotu 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 24, 2010 | 2wire (1000-000057-000) Modem
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
May 20, 2010 | 2wire (1000-000057-000) Modem
(1000-000057-000) Modem: Modem will not turn all the green lights on...
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at abotu 18 mos to 2 years. Mine is almost exactly at 2 yrs.
May 18, 2010 | 2wire (1000-000057-000) Modem
Why won't my 2wire modem stay on?
maybe its either cable issue or modem itself
>> try to hard reset it...unplug first the power cord to the power outlet then press for 5 seconds the reset button(usually at the back of it)...then let it turn on by plugging the power cord to the power outlet...then it should be working fine...if not check with your modem tech support and ask if there is any outage or check if it is already need to replace the modem( if it is already over a years)
Apr 08, 2010 | 2wire (1000-000057-000) Modem
The on-off switch on Speedstream 5100 modem keeps turning itself off, every few hours for few days. Finally modem has no power, what could the problem be? already tried replacing the power cord but still...
1: unplug all the cords to the modem
2: press the reset button from the back of it
3: leave it for about 5 minutes to drain off the static charge
4: plug it only to power source to see if the power lights up
5: if does'nt don't waste your time on it, its bad and if it was provided to you by your internet service provider get it replaced for free.
6: if you bought it yourself check for warranty generally modems have lifetime warranty
Dec 12, 2009 | Efficient Networks SpeedStream 5100 Modem
I JUST GOT A GATEWAY M465E NOTEBOOK ON 07' ,IT WONT POWER ON!!! I THOUGHT IT WAS MY CHARGER SO I BOUGHT A NEW 1 FOR MY EXACT MODEL & IT STILL WONT POWER ON! IM TRYING TO SEND IT BACK FOR REPAIR OR A...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 22, 2009 | Gateway M465-E Notebook
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
Router unable to connect to internet
Are the info coming from PC connected to modem?
If you are connected to Router and pulled up that Data, you might just need a power cycle. Turn off everything from PC to router - to Modem and Power on everything starting off with the modem this time. After power cycle, check if getting the same data. If yes, then type "ping yahoo.com" if you have four replies then you must be able to go online, if not then disable firewall (norton, maccafee etc)
Oct 04, 2007 | SMC Barricade g SMC2804WBR Wireless Router
Computers & Internet Logo
67 people viewed this question
Alun Cox
David Payne
David Payne
