Question about Sony MDR-7506 Professional Headphones
How to replace blown driver.
Right side just stop working where can i get replacement drivers?
  • brainwreck Apr 20, 2008
    wubanger, your problem could just be a loose wire at the voice coil. there's a plastic cover over each driver which have the sony logo and model #. if you look on the topside of each cap, there's a small phillip head screw. remove it, and remove the cover. the left side can be a little tricky, just pry at the top where you took out the screw, and then push down on the cover toward the cable. there are four wires soldered to the driver where the cable comes in to the phones. the driver on the other side has two wires. make sure that none of these wires have broken loose. if a wire is loose, you'll need to solder it to it's contact. something to keep in mind is that most heaphone wires have a invisible teflon (i think it is) coating over the wires which needs to be removed at the point of contact. if that's not the case, i don't know where new drivers can be purchased.
    my sony mdrv-600s recently developed some distortion in the right side. i'd like to find replacement drivers but i don't see them available any where. it really sucks getting used to a set of phones to have them fail but it's even worse when the manufacturer doesn't provide replacement parts for repairs, which would be really easy to do for someone with soldering experience.
By the time you buy a driver from Sony for $78 you may as well just buy a whole new set for $94.
Posted on Jun 09, 2008
The drivers side front turning right ligjht doesn't work
Investigate first, by tapping the cover sharply, to see if there is a shortage. Secondly - If not it may be a blown bulb, or a blown fuse. Third (Last) - check the wiring, and replace or have replaced accordingly.
Mar 13, 2014 | 2001 Lincoln Navigator
Headlight fault
You may have blown a fuse, check fuses first then before you try to replace the bulb again check for broken wires or the correct bulb
Oct 25, 2017 | 2008 Kia Pro-ceed 1.6
I have a 96 Explorer with keyless Alarm and the windows stop working can we fix it
if all windows stopped at once, it sounds like it could be a blown fuse. Fuse boxis on the drivers side,side of dashboard.pull it out to see if blown and replace with same amp number.you could also look in manual for info on fuse box.
Feb 02, 2012 | 1996 Ford Explorer
The driver side window does not work but i can still control the other windows in m car from the driver side also the moonroof does not work and the radio and time do not work?
Hi! Regarding the driver side power windows please try cleaning the contact of the control for it could be corroded causing it not to work. Regarding the radio and moon roof, please check for blown fuses and relays which can cause electrical failure. HOpe this helps and have a good one!
Aug 05, 2010 | 2005 Ford Five Hundred
Driver side brake light won't work. Bulbs are new. 2003 Grand Caravan
Pull down the fuse/relay panel under the driver side dash. You will see a fuse for each side of the van> Right brake light and left brake light. Check the fuses for a blown fuse controlling the drivers side and replace it with the same size fuse. Hope this will help you.
May 15, 2010 | 2003 Dodge Grand Caravan AWD
I have lost my dashboard lights and all gauges do not work. I assume a fuse is blown but can not find it. I have checked all the fuses in the engine department but can not find the fuse box which should be...
The manual shows clearly that the fuse panel is located behind the kick plate on the driver's side on a right hand driven vehicle (right side of the vehicle).
The fuse box is actually placed on the passenger's side ( left side of the vehicle).
I replaced 15 amp fuse for gauges and it all works again.
Nov 07, 2009 | Car Audio & Video
2002 Hyundai elantra driver side turn signal not working outside
This simply means that the front driver side turn signal bulb has failed. Replace it.
Oct 28, 2009 | 2000 Nissan Maxima
I have a 2008 GMC 2500. My cigarette lighter (not the Aux 1 or 2 power jack) stopped working and I check all the fuses. None are blown but I have no power. Are there any in-line fuses in this circuit?
Check fuse 55 in the eng. comp. and check the power fuse "alt pwr" 20A in the driver's side fuse panel on side of dash.
I melted my right side power plug with a portable compressor and blew the fuse in the dash panel. I need to get a new power plug now.
Sep 10, 2009 | 2008 GMC Sierra 2500HD 2WD
Sony MDR-7506 Professional Headphones Logo
690 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
