Question about Philips DVP5982
HDD 500 gig will not work USB
I cannot get my western digital 500 gig HDD to work when i plug it in via usb. every time i try i get a device not compatible error. it's bugging me becasue that's the only reason i bought this dvd player advice anyone?
  • 1 more comment
  • kamuran m?layim Mar 06, 2008
    HI I just purchased Philips usb powered 160gb external harddisk and formatted to fat32 but player didn't recognize it.
    could it be usb bus power insufficency?
    can I overcome the problem with an external power adapter
  • asga May 04, 2008
    I've succesfully used a Lacie 80 GB USB HDD in my Philips 5960. But I recently bought a 160 GB one, and says "incompatible". I even reformatted it to FAT32 with no success. My guess is either power or something like sector size.
    (the manual also says USB is just for JPEG and audio, but videos play fine, so the manual is not perfect)
  • leblonman40 Apr 10, 2009
    The same issue with WD Passport Elite 500 Mb External HD and Philips DVP 5990K/55. I've gone through 2 FAT 32 formats already and no luck yet. I will try this Swiss Army application, but am not too optimistic.
You can use that HD or any Hard Drive for that matter, only thing is, that you have to have it formatted in FAT32 format, not NTFS which it probably is by default nowadays. There is a program called swissarmy and it will format any drive to fat32, and you will be able to store whatever u want on there like a normal drive, basically u wont notice a difference except the fact that now it works with your dvd player.
Posted on Feb 28, 2008
Hi this DVD player does not support HDD players as per manual. only flash players
Posted on Feb 18, 2008
Its probably not in FAT32 format
Posted on Jan 21, 2008
6ya staff
SOURCE:
My wd 500 gig external hard drive keeps blinking and my computer doesnt recognize it. whats going on?
How do you have it connected to your PC? USB or Firewire? try plugging it in to different slots or try plugging it in on another computer to further isolate the problem. some external drives requires power adapter to work so make sure that you're using the power adapter if it comes with the device. if not, there might be something wrong with the device specially if it was working before
Jul 17, 2009 | Western Digital My Book Essential Edition...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
Western Digital External hard drive not appearing under my computer or anywere else apart from Device manager (USB mass storage device) and safely remove usb hardware, have tried another comp with no luck...
1st dismantle the hdd and change sata to usb adapter. Get cheap on ebay. Certainly, most wd makes hdd motherboard with usb straight away, but still worth to try. BUT, before all check if your pc usb is working, check with mouse or smth. If so, then try change cable. After cable try dismantle that hdd and change mentioned adapter. If none of these work, you then have a lesson, never western digital, seagate only1
Feb 18, 2018 | Western Digital Passport 320GB External...
I have a Western Digital HHD with S/N WXEX07D27706...I always get this messege that Device Not Recognized when ever I plug it to the USB port.pls help me out....cos I have alot of files in this external...
The problem you're having is unfortunately common. You can try to test it with a new USB cable but if that doesn't work. Chances are you will need to send it to a pro.
If the USB cable doesn't work get back to me and I can recommend a service that can aid you further
Hope this Helps,
Chris
Armor-IT
Apr 25, 2009 | Western Digital My Book Home Edition 500...
Dell d400 problems with Western Digital 32 gig hard drive
try connecting to a differnt port if it still does the same thing change the usb cable because what i understand is there is a loose connection somewhere ... or the best thing is contact dell at 18006249896 and ask them that u want to change the internal hdd and they will tell u what maximum the system can support and which is available with them ... its their system and if u buy parts from them they have to support u and make sure they both work
Feb 07, 2009 | Dell Latitude D400 Notebook
External Harddrive Ignorance...
I've seen this happen with hubs being connected to external hard drives before.
Do you have a free usb port on the back of your computer you can plug it into?
That should fix the problem.
Jun 11, 2008 | Belkin (F5U233-APL) 4-Port USB Hub
120 gig Western Digital black no longer mounts on LEOPARD osx 10.5 grrrr
i have the same problem.
macbook doesn't see anymore my hdd western digital 2,5'' white 250 GB.
tried disk warrior, disk utility but nothing.
it's just seem disappeared, even if i hear it works inside (and the led light is on)
what can i do?
May 10, 2008 | Western Digital Passport WDXML800UE...
Mybook essential
Hi guys...
I had kind of the same problem like u...when i plugged it into the usb all i got was a "unknown usb device found"
I opened the external case hoping the hdd was still ok only to find out that the hdd cables had been moved slightly out of position..propably from a fall or a knock I didn't even noticed..
I just pressed them back in..click..and everything was back to normal..
These sites have info about how to open the external case..
http://rebootdaily.blogspot.com/2007/03/how-to-open-western-digital-my-book.html
http://anotherdeadblog.blogspot.com/2007/09/how-to-open-western-digital-my-book.html
Hope that helps!
Nov 29, 2007 | Western Digital My Book Essential Edition...
Philips DVP5982 Logo
220 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
