Convergence problem? I have the old school Sony KP 41T65 - 41 inch for my garage T.V. and I am having trouble with the picture. The Green portion of the picture is showing up concaved on the screen. I can play around with the convergence and get everything centred in the middle of the tv, but is doesn't match up on the top and bottom of the screen. I have tried to look for possible solutions that may have already been posted, but I can't seem to find anything that will help me in troubleshooting the problem. The weird part is that I can get everything to match up just by tilting the tv backwards. Any help would be appreciated.
  • sonytrouble9 Jan 28, 2008
    If it was a losse mirror, would it not affect all three projectors (whole picture)? It is only the middle/green that I am having trouble with. I have checked the connections and can't seem to find any problems.
  • 8,617 Answers
If evrything lines up when you tilt the set backwards , you may just need to make sure the mirror is tight. The clips may have loosened over the years therefore throwing the aim out of alignment. If the mirror is tight ,then I would suspect a loose connection. You might try having a mirror and try moving some wires with an insulated tool from behind while you look into the mirror to see if it has any affect on the convergence. Could be something as simple as a loose plug. Hope this helps.
Posted on Jan 17, 2008
6ya staff
SOURCE:
I have sony KP-65WS510 TV, started reporting convergence problem and showing pictures 3 different color. After I talk to Sony Technical Support turn OFF and ON method for initial trouble shooting.Now TV...
Tv have convergence problems first,fix the convergence board first.The tv have mis R,G,B colors lines alignment have 3D pictures effect.The tv convergence board have totoal dead 2 ICS convergence ICS and some or all it resistors.U know how to do basic's soldering?U have tools like a soldering iron,desoldering pump or solder witch and solders?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy ur tv make and model of convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.Now,the projection lamp, might need to replaced too,after fixing the convergence problems.
Aug 27, 2010 | Sony KP-65WS510 65" Rear Projection...
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
The tv picture looks like should be wachting it whith 3d glasse
This is a very common failure on Projection TV sets. Its called a convergence failure. Here are some common symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
The other common problem is cloudy lens fluid. After many years the coolant in the blue and green lens will become cloudy and cause the screen to look dull, red/orange, bright white, etc. You may even see halos around objects on the screen.
You can see some example photos and find a solution here on Fixya.
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
I have a Sony KP-51WS510 and the convergence is
Dear Doctor,
Check pico fuses PS8001 to PS8006 on D board where you replaced both STKs.
Make sure +22 volt and -22 volts are being supplied from power supply (G board) to D board.
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Green outline on certain areas
Sounds like it needs a convergence performed. Not really something you can do yourself. Requires special equipment and know how.
Jan 05, 2009 | Sony KP-53V75 53" Rear Projection...
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-61v45 Blue Convergence off by 2 inches
you need to replace the convergence board its around 80 dollars
Aug 17, 2008 | Sony KP-61V45 61" Rear Projection...
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence issues
di you check the resistors right next to the s these usually go out with the ICS
Feb 02, 2008 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
