Question about Sony PlayStation Portable (PSP) Console
Psp - have power light but not working
Was using this fine and then it came up if this is turned off this may not start again. and thats what has happend ? Any one know what this means?
  • 1 more comment
  • calix Jan 17, 2008
    Do you know where i can get this from or how i do it or does a professional need to do this. i was mtold buy a fixing place that i have had new software in it and my son has not updated it as the system requested which has blocked the thing. Can i fix this problem myself
  • calix Jan 19, 2008
    Hi what is custm firmware? Im not that great with these things but have friends that may be able to help me. And also what is a pandora battery? thanks you for your help
  • calix Jan 20, 2008
    Hey my psp is the older version say around 2-3 years old. Does that mean the newer version simline would have this. I rung sony and hey said you can it would cost a bit to get them to fix this. they said that the psp would have come up with a note saying please update software. How would a 5year old know how or what that means. So he has gone ahead and kepted going which caused this problem. why don't they inorm you of these things a? Looks like i will need o get them to fix it or do you know other places can do this like gaming shops maybe?
Your psp is bricked. it means that u cant use ur psp anymore unless u unbrick it using pandora battery
Posted on Jan 17, 2008
  • 1 more comment
  • iceshadow Jan 17, 2008
    you can do this yourself but you need someone who has a psp that is on custom firmware to be able to make you the pandora battery.
  • iceshadow Jan 20, 2008
    custom firmware is firmware that has been moded by other people from the original firmware made by sony. to get custom firmware you need to be on the offical sony fimware 1.50 and then download and install 3.80M33 to get you custom firmware. pandora battery is used to unbrick your psp but to make it you need to have custom firmware as it will only work on it.
    i also got the same psp. you dont need to get sony to fix it or any games shop as they would probably do the same thing but charging you for some thing that you can just get off the net.
PSP will only power on about 10% of the time...
Just send it into to sony or buy another one sorry bud......
Oct 07, 2009 | Sony PlayStation Portable (PSP) Console
PSP won't turn on
You can try a hard reset. Do this hold the power switch in the upward position for over 10 seconds. This will cause the machine to reboot. Leave it alone for a few minutes then try switching it back on. You may have to flick the switch on twice to start her up again. If it still has a hard time try changing the battery for the one in your sons machine. MAKE SURE that all apps etc are closed on the PSP first and do the hard reset BEFORE you remove the battery on BOTH machines. Ensure PSP is OFF before removing battery. It is possible the battery has been overcharged or just given up. If the console operates with the other battery you know you need get a fresh one. Consider getting a high power one for extended life. Let us know how you get on. May have more info for you.
Jul 03, 2007 | Sony PlayStation Portable (PSP) Console
How do i reboot my psp?
Have you tried turning on, but then hold the power switch down for around 10-15 seconds or until the power light simply turns off, no flashing. If not, then you should jump on the internet and look for a so-called Pandora Battery and Magic Memory Stick. They will actually install custom firmware on your PSP which you can remove later on, but if you use those, it should unbrick the PSP, so you can use it again.
Sep 24, 2009 | Sony PlayStation Portable (PSP) Console
Green light but nothing comes on
It seems that inside your PSP the LCD Screen Connection cable (The broad One) which is connected to the motherboard is being loose contact so if you can open the PSP try it by re-fixing the cable again otherwise you better go for a technician who will do the same job for you.
Sep 10, 2008 | Sony PlayStation Portable (PSP) Console
Power comes on and it automatically turns off after a while.
try useing recovery mode, hold the R trigger and turn off the power button, then switch the power button back on while holding the R trigger ,that dont work try taking the battery out for some time...
Aug 17, 2008 | Sony PlayStation Portable (PSP) Console
I have a sony 2001 PSP, and I've had it for less than a month and just recently I tried to use it, when i attempt to turn it on I press the power button and the green light (which shows that the PSP is on)...
For how long have you NOT been using your PSP? and did anything happen before you even tried using it AGAIN? Do you have others in your area who has a PSP? if nothing happened to your psp before you tried using it again e.g.accidentally fell or something like that, then just try to use a different WORKING psp battery...if it didn't work, then prolly your PSP went brick and the only solution for that is a pandora kit...
Jul 22, 2008 | Sony PlayStation Portable (PSP) Console
Psp power problem
have you tried charging it
Dec 24, 2007 | Sony ACY-BR81/OB
PSP dose not turn on
Ouch theres a solution called pandora's battery . Google it and look on you tube theres a tutorial for it .CAUTION :MAKE SURE ITS THE FAT PSP NOT THE SLIM or it WILL BRICK IT (RENDERED USELESS)
Dec 10, 2007 | Sony PlayStation Portable (PSP) Console
Power light on but still not working
Check ur firmware, (if ur PSP installed custom firmware e.g. OE, M33.) goto "recovery mode", press and hold R(right button) while turn on ur psp. if u can go, simple use pandora battery for downgrade/upgarde ur psp. see at, http://e-arena.blogspot.com
Oct 22, 2007 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
