Question about Thermador C302U Electric Double Oven
BROIL ELEMENT DOES NOT HEAT
My C302US Thermodor broil element does not heat. I checked at the terminals and no power (electric) is coming there. I by passed the thermal fuse, still not working. Broil element has continuity and thermal fuse has continuity too. Please advise............. Its may be the main electric board but i want to ake sure before i change it. Any suggestion??
Sorry I could not test this solution because the customer bought new oven. thank you for your help.
Posted on Feb 01, 2008
  • 25 Answers
If it is only the broil that is not working the the problem is more than likely the main board, the thermal fuse and double line break relays will affect all the elements in the oven in question. Due be careful the likely hood that you have no voltage at your element is not very good. If you have the terminals connected to the element you are probably reading a zero potential, try measuring from terminal to chasis ground should get 120v. on the main control looks like k-9 for the upper broil and k-13 for the lower broil relays
I have a Samsung electric range FTQ352IWUX, and neither oven functions (bake nor broil) produce any heat.
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 18, 2015 | Samsung Ovens
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Broil does not work
the broil element
Aug 05, 2014 | Kenmore Ovens
Broiler turns to pre heatworks oven doesnt heat when temp
the broil element
Apr 15, 2014 | Kenmore Ovens
Broiler won't work
the broil element
Apr 14, 2014 | Kenmore 47702 / 47704 / 47709 Electric...
Broiler wont light
the broil element
Mar 17, 2014 | Kenmore Ovens
Oven won't heat up, display flashes bake
THINGS TO CHECK:
the broil element
The bake element
Feb 12, 2014 | Frigidaire FEB27S5A Electric Single Oven
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
Thermador SEC301BB broiler doesn't work
the broil element
I have Whirlpool RBS305PDB16.The bottom broiler element will not heat up only the top.Any ideas on the problem?
the broil element
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Nov 16, 2012 | Whirlpool RBS305PD Electric Single Oven
Thermador C302U Electric Double Oven Logo
290 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
