The mini CD only has 98 and ME on it since VISTA came out AFTER the drive. The manufactures site supports the same drivers and XP and bellow are already installed.
Vista is missing on a drivers pool.
I am in the hope that someone has learned the trick to making this compatible with Vista or may have a third party driver. Much cheaper option than buying a new digital camera.
Comment by chris04, posted on Feb 20, 2008
Well I have been looking for the files and I found alot but none that seem to have the correct info accoding to Vista.
Can you email the ones that you are talking about please I would like to try them out and see if I can recreate your solution.
thanks
chro4 I use AOL.com
chro4@aol.com
Good try but I am lacking here. I found a TON of files and the ones I have tried do not have the right configuration per vista.....lol
can you email the ones you found and worked with so i can recreate the fix suggestion.
I use the aol service and the account is chro4 incase my email id does not go thru when i submit it in the post chro4@aol.com
Thanks
You should have (if bought new) had a mini disc in with the drive. If not try the manufacturers site and download it. It's also possible by doing the add/remove hardware and pointing towards Microsoft for the driver it will install for you. Hope this helps...Tango.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on need vista driver for FD-05PUB teac usb floppy drive:
Solution #2
posted on Feb 16, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
After an agonizing hour of searching, I found this solution.
Unlike Windows XP, Win Vista lacks the generic drivers for USB devices.
So the workaround is to copy the XP USB drivers into your Vista system32\inf folder.
1.Specifically, google for these two winXP files:
usbstor.inf
usbstor.sys
2. download and save them into your windows\system32\inf folder
3. Pop in your device and allow the drivers to be searched manually and point to the above location.
Presto! The usb device now works fine!
A great step backward from Vista to XP if you ask me!
