Question about Competition Crystal COMP 10 - 10" Subwoofer - 500W RMS Car Speaker
Finding the right speakers
I have a 1995 impala and im working off of a alpine head unit and I can't find any 6x9's that won't sound distorted when I turn it up what kind and how many wats should I use and who makes a good component set that will go along with the two
  • bigmike6 Jan 19, 2008
    What do you mean on the back seat. im tryin to keep tha original look but still have custom things in it im lookin for sumn to put in tha back deck
Dude, the other guy who answerd you first doesnt know s@$t. Infinity has a clean crisp 6X9. Take a pick in your price range, The solution is to put the 6x9 in this foam like casing that keeps the sound from distorting with your subs in the trunk.DO NOT start cutting holes and throwing insubs in yor rear window area, That is ghetto s@#it., Other 6x9 I recomens, Kickers, Mephis Audio and they will give you bore bass though, As far as componets keep them in your front doors and if you really want a good I idea, your backseat has a folding center arm rest. Perfecy size area for a sealed 4 way 6x9. But dont use it for bass, a nice mid sound and tweer.
Posted on Aug 04, 2009
  • 2,039 Answers
You should install 2 8 or 10 inch wooffer on the back seat install mid range and tweeter its not very expensive it gonna sound great with that trunk you can do anything you whant 6x9 its sound like crap even the expensive one
Posted on Jan 18, 2008
Cd player wont load ?
is it the original unit ? if so they fail .mine failed twice once under the 5 years cover then just outside .so i bought a better unit and replaced the speakers and added a small under seat ken wood sub .the sound quality is excellent if you have some basic DIY car electrical knowledge its a easy job to do just take ypour time many new head units come with DIN wiring so will fix on without any extra wiring you may have to add a live just take from cig lighter its easy to get to .there are you tube videos to help you ..the speaker that came with the car will need to be changed because they will sound poor with a new head unit .i used 6 and half inch hertz speakers and a 6x9 kenwood sub with an alpine head unit ..its very nice quality sound .
Feb 20, 2014 | 2005 Hyundai Tucson
Alpine 6x9 speakers 90 watt rms.Are they compatable with a pioneer gm 3000 amp
the alpines will take every drop of power from that pioneer and smile... it will sound quite good,and if you ever want to you can actually put about 2x that much power to them 1 of those amps per 6x9 would rock
Apr 08, 2013 | Pioneer GM-3000T Car Audio Amplifier
How do i install 6x9 speakers in a 1995 oldsmobile cutlass ciera?
No brackets are necessary...I believe you are talking about replacing the rear speakers located in the rear wondow shelf...Of course the speakers mount underneath the window inside the trunk...You can remove the rear seat and pull the interior trim back to view the top side of the speaker mounting...The opening is already cut for the 6X9 speaker...You can mount the top underneath the window cloth material like the factory did, or no need to remove the interior cloth if you use new top speaker covers, usually come with the speakers. Hope this helps.
Sep 06, 2012 | Cars & Trucks
Dont want to lose stork controls and trip computer on fiesta st??
You have to bypass your entire factory system, it takes some customizing and careful installation, too much information to write over Fix Ya advice, phone or actual physical support in a car stereo shop is your best bet.
Good luck my friend.
Jun 19, 2010 | Alpine CDA-7892 CD Player
Whats the best alpine 6x9? dds-r69g,sps-6939,spr or others
All of these work nice, remember the quality of the sound depends primarily on the source ( car stereo and/amp) and then the speakers, you need to know what Ohm and what watt is the minimum requirement for your sound system.
Feb 07, 2010 | Alpine DDS-R69G Car Speaker
How do i get the bestsound out of my aline head unit.i have got a b.m.w 535 with alpine 6x9 inthe rear self a boombox in the boot and alpines in the footwell.and iva-d105r head unit but i cant seem to get...
What amplifier(s) are you using. How many, what size subwoofers and what type of enclosure are they in? What is the crossover frequency and slope? Active or passive x-over?
Apr 29, 2009 | Alpine Car Audio & Video
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Competition Crystal COMP 10 - 10" Subwoofer - 500W RMS Car Speaker Logo
131 people viewed this question
Top Competition Car Audio & Video Experts
xxxxxx xxx
Are you a Competition Car Audio and Video Expert? Answer questions, earn points and help others
