Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi wd 57731 1080p
My tv giving a signal that the air flow is block but It is not close to the wall it has plenty of room to breath it wasnt so bad but now it does it all the time.
  • sally241 Feb 22, 2008
    My tv is a Mitsubishi wd 65731 and I get a message on the bottom of the screen saying the tv will turn off in a few minutes. please check the air flow to see if it is blocked. I have dusted everything and it is still doing this.
  • pinstigerboy Mar 18, 2008
    same problem
Mitsubishi WD-57731, 15 months old, engine light bad. Great color for 1 hour then turns green, Repair is $1,500, can't afford. Can I buy and replace engine light myself?
Posted on Feb 19, 2008
  • Edie Spalding
    Edie Spalding Dec 29, 2013
    Run a fan on the back of the TV when it is on. Ours did the same thing. We were told it needed a neew color wheel. Running the fan solved it.
    President:
  • 4,402 Answers
See if there is dust inside blocking it.
Posted on Jan 18, 2008
Third time replacing 65" mitsubishi dlp bulb ?
Use Osram or Phillips bulbs
Check for blocked air flow
Always allow TV to complete cool down with plug in wall
Check/Replace ballast
Aug 22, 2016 | Mitsubishi WD-65638 65" DLP HDTV
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
Air flow problem
Pull Lamp Out and see if when you try to turn it on if the Ballast Board has a spark/arking noise coming from it? If So Replace the Lamp.
Jan 14, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Message that TV is powering down, check air flow for obstruction
Mitsubishi has had some problems with these sets with the lamp cartridge(google the model number and look for how to replace lamp instructions) On some of the lamp cartridges they covered several openings with a fine screen like material---one is narrow and completely blocks up with dust---this will trigger the air flow message--if you get the lamp out and this screen is blocked, carefully clean the dirt off with a brush---if you don't get it soon enough it will kill the lamp----the replacement lamps for these sets use a bigger mesh that does not block with dirt---it blocks because there is a fan the pulls air and dirt into the set to cool the lamp during operation.
NEVER TOUCH THE FRONT GLASS OF THE LAMP WITH YOUR HAND
I do this here for free so if this helps you give me a vote here.
Aug 24, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi wd-65731 ,won't be able to keep it turn on
Call Mitsubishi at 1800-332-2119. Explain the symptom and they should be able to direct you to a service facility that will replace a Temperature Sensor at no charge to you. It is a known failure. Good Luck. Don't wait to call.
Skyassoc
Jul 04, 2009 | Mitsubishi WD-65736 Television
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 56 inch dlp,screen says tv will turn off in a few seonds,air flow seems to be blocked,tv turns off and orange light comes on???? Have to push reset button to clear orange light,this is constant...
Hello!! It might be either that the tv is overheating because of the lack of air, or it may also be your ballast.
First of all I recommend you clean the fans, so the air flow won't be blocked, don't use something that mioght damage some of the boards that are inside, you can buy one of those air cans to clean computers, if that does not work, I recommend you listen closely and notice if there's a clicking sound, if so it might be the ballast.
Mar 14, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Airflow blocked tv will shut down after a few seconds
Good Day;
If you have a WD-52525 Model TV and the the screen displays "air flow problem" change the sensor. There's not a positive way to check device, just replace it, trust me. IF your TV is a different Model MIT'S has a recall on those certain Models. REPLACE.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-65731
AIr flow is blocked?.....is this the message you get on screen mitubishi have a problem with what is called the thermal sensor.. the processor says its getting to hot... mitsubishi suggest service center replace this thermal sensor.
Jun 02, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
277 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
