Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
My saco vienna superautomatica has been in storage. How do I get water to pass through the machine
My machine has been in storage for 2-3 years. How do I restart the water flow? Sadly, I no longer have the guide...
  • 2,039 Answers
Fill up the water tank try it if nothing coming out in the starter kit they give a plastic pump if you have fill it up with water remove the water tank in the center hole were the water goes put the pump and force water in there if you dont have the pump try to inject water in there with at turkee pump anything you got it gonna prime the pump put water back open the valve for the water on the side where you do the milk should do it cheers
Posted on Jan 17, 2008
Saeco vienna digital sap18d keeps saying fill resivor and we have plenty of water in it and beans are full
Posted on Mar 27, 2008
  • 3 Answers
I need instructions of how to clean the Saeco Vienna Superautomatica in and outside. We lost the manual.
-Rinse Brew unit under warm water, and let dry.
-Rinse coffee tray, water tray and water tank under hot water (may melt in dishwasher)
The rest coffee been tank and exterior needs to be washed with a warm cloth, just make sure it is not to damp, which could leave water drops in the grinder.
Feb 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Tengo una saeco vienna superautomatica, y a empezado a perder agua del deposito por la toma de salida, que puede ser?
hola :)
Try changing the seal under the water tank: NM05.006
(Intente cambiar el sello en el tanque de agua)
Jan 23, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
How do I change the aqua filter in the Saeco Vienna Automatica machine?
it is not a filter but a water softener and no need to replace. You need to pass thought it 2 spoon full of salt desolve with water and then flush it with water for 15 min until the salt will be cleaned. You can do this one time per month so to avoid any scale build inside the machine.
Dec 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Caf?© SuperAutomatica: Grupo de distribui?§?£o
remove the service group and soak for a half an hour in a pail with 1quart of water to one cup (8OZS) of bleach.now dry it off outside in the sun or use a hairdryer now try to see if water will pass thru quickly or repeat the to soakit one more time. good luck! ru
Sep 21, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
295 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
